01-30-2004, 11:42 PM | #1 |
Project92 SWB stepside
SBC 406 450 hp For Sale!!
I am buying a BBC project from a fellow Member so my fresh built never ran 406 must go. Specs are as follows. 2 bolt main 400 block machined .030 align bored and checked for run out fully clearanced Mag checked and pressure checked Hot tanked and Jet washed Bore torque plate honed to give true pistons walls Rods have been shotpeened Assmebly has been dynamic balanced file fit rings blue print clearance New cam bearings mains and freeze plugs Speed pro Hyperutectic Pistons 9.8 to 1 Race prepared nodular iron crank micropolished and wear sized and indexed. Childs and Albert moly file fit rings GM PINK RODS pioneer bolts Pete Jackson gear drive Lunati part # 0012lk cam with .550 lift at .050 3/8 Rocker studs with roller tipped rockers new push rods Fel pro gaskets 7 degree lock and lunati valve springs Gm cast heads that have been stage 3 ported and polished 2.02/1.60 s/s valves These heads flow very very well and the port work is awesome!! 76CC head. Have over $3000 invested Will take $2600 for it. Pm me for more info!! Engine was built by a builder in Virginia and has a great reputation. Here is a link to his website http://www.maxhorsepower.com/ Mark Lim is the builder. Call me at 502-376-9408 if needed. Eric Also includes performer Rpm intake. Rods are 5.7" forged gm. Will Ship!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 Last edited by phantom dually; 02-06-2004 at 09:12 PM. |
01-30-2004, 11:45 PM | #2 |
I also will post pics asap.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-31-2004, 12:37 PM | #3 |
ttt
01-31-2004, 05:43 PM | #4 |
What cc's are the heads? Would you consider selling just the assembled shortblock?
01-31-2004, 10:53 PM | #5 |
I would really like to keep this all together. If the price were right then that would be a option. Pm me with any offers!!
01-31-2004, 10:54 PM | #6 |
76CC with 9:8.1 compression.
02-01-2004, 07:45 PM | #7 |
I will also pay meet halfway on shipping up to $400
02-01-2004, 08:31 PM | #8 |
pic#1
02-01-2004, 08:31 PM | #9 |
3#
02-01-2004, 08:32 PM | #10 |
pic
02-01-2004, 08:33 PM | #11 |
pic 5
02-01-2004, 08:34 PM | #12 |
Exhaust ports. Tried to get good pic of awesome port work.
02-01-2004, 08:36 PM | #13 |
Sorry about the crappy pics here!! The tape I had over the exhaust ports has left a sticky film that will come right off.
02-02-2004, 09:55 PM | #14 |
TTT
02-03-2004, 01:02 AM | #15 |
TTT
02-03-2004, 07:13 PM | #16 |
Bucket of Bolts
Are they 5.7" rods? Also, would you take a vehicle trade (Jeep Cherokee)?
This is the project that never ends, yes it goes on and on my friend.... |
02-03-2004, 08:15 PM | #17 |
They are 5.7 rods. Also I would prefer to sell outright. But if the vehicle is something that would move quiclk I would consider it also. Pm me to talk further.
02-04-2004, 11:05 PM | #18 |
TTT
02-05-2004, 12:37 AM | #19 |
Bucket of Bolts
I PMed you, but your mailbox was full.
02-05-2004, 12:49 AM | #20 |
It is now emptied Sorry!!!
02-05-2004, 03:10 AM | #21 |
Bucket of Bolts
Hey, since your PM box was full, I emailed you...did you get that? If not, I can re-PM.
02-05-2004, 10:15 PM | #22 |
I will check or try sending to jegray@bellsouth.net
02-06-2004, 09:13 PM | #23 |
TTT
02-06-2004, 09:16 PM | #24 |
Bucket of Bolts
Sent PM again
02-06-2004, 09:20 PM | #25 |
Got pics??
