Old 03-30-2002, 05:51 PM   #1
seth69c10
Post Need help with Quadrijet 4-barrell
I have a 305ci motor in my 69 C-10, and I think that I have a problem with my Quadrijet carburator. I don't think that the 4-barrell is kicking in. If I am going down the road at 30-40 mph and I floor it, I feel or hear nothing. Now I know that a 305 won't throw me back in the seat, but shouldn't I feel something or at least hear the 4-barrell roaring?
Thanks for the help
Seth
1969 C10
SWB, stepside, p/s
rebuild completed
1969 C10
SWB, stepside, p/s
rebuild completed
seth69c10 is offline   Reply With Quote
Old 03-30-2002, 06:54 PM   #2
Benrs86
Benrs86's Avatar
Post
you should definately feel it, at least i could with my quadrajet. it is easy to fix. go to your parts store and ask for a perfromer intake and a 1406 carb. that is a AWESOME setup. i have had mine for 8 months now and have hardly adjusted a thing. WAAAAAAAAAAAY more powerful. i love it. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 03-30-2002, 07:10 PM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
check the adjustment on the secondary linkages, vacuum diaprhagms etc. you may be opening the throttle plates, but not the butterflys. You can check it by looking down inside the secondaries holding the butterflys open and opening the throttle to wide open. Your pedal linkage may be out of adjustment too.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-30-2002, 09:14 PM   #4
truckster
truckster's Avatar
Post
Your quadrajet is probably just needing a little adjustment. The Q-Jet is a great carb, and will make a ton of power if set up properly. It's dependable and I wouldn't trade my 800 cfm Q-Jet for any aftermarket carb.
Assuming the carb is not fouled (they're easy to rebuild), I'd look at the choke pull-off and the air valve spring adjustment. On my 455 I had the air valve spring set to open right off idle, but you probably want to adjust it for good economy as well as power. Here are links to a couple of good articles on adjusting the Q-Jet:
http://www.hotrodding.org/enginetech13.html
http://vetteworks.tripod.com/Qjet.htm
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-30-2002, 10:47 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
The choke flaps might not be opening up when it warms up...when it's in a cold condition, you can't get the secondaries open. If it's not set right, they might not open no matter how hot it gets.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-02-2002, 01:55 AM   #6
seth69c10
Post
Thanks for the help!!
Any more suggestions?
1969 C10
SWB, stepside, p/s
rebuild completed
