![]() Join Date: Aug 2001
![]() ![]() I'M IN NEED OF A GOOD STRAIGHT HEADER PANEL FOR A FLEET BED WITH A WOODEN FLOOR. WILL BUY OR TRADE. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Try an adapter flange
John if you have a good panel from a steel floor bed consider using one of Mar-K's adapter flange. There part # is 100625, $20.00. from their web page;
"Front Bed Panels Adapter Flange This angle may be used to convert from a steel floor to a wood floor. This is used with the original front bed panel for conversions since the wood floor front bed panel is taller than the panel for the steel floor. This part is welded on to the existing panel. It can also be used to repair rusted panels. This part is not necessary if purchasing a new front bed panel."
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
![]() WOW ..... THANKS LARRY. I DIDN'T KNOW YOU COULD GET AN ADAPTER TO GO FROM A STEEL BED TO A WOODEN FLOOR. I JUST ORDERED THIER CATALOG. THANKS AGAIN. ![]() ![]()
![]() Join Date: Jan 2003
I just odered a catalog too. Thanx BAD4x4
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
Chevy Duty also has that same part for conversion from steel to wood for the header panel.
Alex 1971 Lil' Red 350 SBC 700R4 |
