02-01-2004, 09:52 PM | #1 |
Upper Ball Joints
What size drill bit do you use to remove the rivets for the upper balls?
1969 GMC S/B S/S 3" drop |
02-01-2004, 10:04 PM | #2 |
i've always just used a grinder to grind the heads off and a punch to drive the rivet out
02-01-2004, 11:26 PM | #3 |
I ground the heads down on mine. Then chiseled the remaining portion of the heads off and pushed the rest out the bottom using a punch. I decided to go this way rather than dill so I would not elongate the holes.
Mike 67' GMC Fleetside |
02-02-2004, 12:55 AM | #4 |
I GRIND THE HEADS OFF THE RIVETS & DRIVE THEM OUT WITH A PUNCH IN A AIR HAMMER. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-02-2004, 03:08 AM | #5 | ||
Hey Junk yard did you reciev the $$ I sent. I never recieved a response from you. ??
rich
