Old 02-01-2004, 10:58 PM   #1
Angry Need Help before I kill it!! OT some
Trying to get an electronic choke working on the 250Ci 6 in my 82. It has the 2 bbl Rochester E2SE, my friend calls it the Japanese rochester. I've ben trying to get the electronic choke to work correctly to make the daughter's life a bit easier. I'm waiting on my third choke to try. It appears when the coil heats up (makes the spring tighten) it is turning the wrong way and forces it to stay closed. It's not pulling back the pull off. I'ver matched the carb numbers (Carb# 17082482) at NAPA and they say the one I had is was the book says goes for the carb. When we rebuilt the carb, we didn't pull the lever that the choke coil hooks into off, so it is factory position.
I am very confused and wondering if any of you folks ran across something like this or give some idea to figure it out.
The lever at rest is pointing at about 11 Oclock and needs to turn towards 9 oclock to have the choke fully open. The last choke had the range when it heated and cooled, just went in the wrong direction.
I'm waiting on another choke from a different parts outlet to see if that might be the case, but I have a hunch there is something I missing.
Thanks all.
Old 02-01-2004, 11:04 PM   #2
barn9
Half a bubble off!
barn9's Avatar
Bill, you might ask Piston about this, there's a fair chance he'll know. Good luck!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-02-2004, 01:13 AM   #3
kwmech
Sounds like the part may be misboxed or totally incorrect, make sure the next one has the spring wound lthe opposite way.
Old 02-02-2004, 01:25 AM   #4
veltex
veltex's Avatar
I'm sure you tried this already, but is it possible to turn just the spring over?
beater 65 gmc at the moment
veltex is offline   Reply With Quote
