Old 02-02-2004, 08:04 AM   #1
TIMSPEED
TIMSPEED's Avatar
OMG! Seen two nice 81+ front clips in the JUNKYARD!!
Shyeah. So, I was hauling off our old water heater tonight to the scrap yard...and I pull in and drop it off, and what do I see??? None other than TWO 81+ cab/front clips. Upon closer inspection, they're 100% solid, no rust!! Both are completely assembled. But nothing else was there besides the core support/fenders/cab. Amazing what some people will throw away isn't it? I MAY go back and see if I can't score one of them, and then swap it on mine and do the 88-91 Burb front grille swap...dunno though, I kinda like the original 75 grille, as it says "350" in it.
Dunno though, cuz the place is a SCRAP yard..not a wrecking yard, who knows, maybe they'll give the parts for FREE...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-02-2004, 09:36 AM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Take 'em both if you've got extra free space, i bet you could use one of them, sell the other and buy all the parts for the 89-91 conversion without having to spend any money. That is, if they're free...
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 02-02-2004, 10:27 AM   #3
bigblock73
yeller
bigblock73's Avatar
I guarantee they won't be free, and I bet you aren't the first person to see those and possibly inquire about them.
Doesn't hurt to check though.
I would keep your original front end...looks better than the cheesey 81+ j/k guys
bigblock73 is offline   Reply With Quote
Old 02-02-2004, 10:44 AM   #4
bigd65
bigd65's Avatar
HHEEEEEYYYYYYYYY, I like my CHEESEY 85' with 91' GRILL
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 02-02-2004, 03:02 PM   #5
r0lf-
Hotwheels?
r0lf-'s Avatar
Nah. Keep the original 73-80 front end. It looks way more classic.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 02-02-2004, 03:20 PM   #6
bigblock73
yeller
bigblock73's Avatar
Tim, kind of off topic, but how do you know your truck only weighs 3650 pounds? These trucks tip the scales above 4600 pounds (2wd shortbeds).
Old 02-02-2004, 07:28 PM   #7
RockHQ
ROCKET POWER!
RockHQ's Avatar
Bigblock73, my C-10's title says it weighs 1980kgs (4400lbs), that was with the 350 olds diesel, TH400, 12 bolt rear, 6 leaf rear, hydroboost, no power anything, no tilt wheel, no headliner, single tank, dual battery, short fleetside bed. These trucks were weighed at the customs inspection upon arriving here, before the dealership registered them, so i believe it to be somewhat correct.
If i had to guess, an otherwise identical truck with a chevy sb, th350, single battery, vacuum brakes could get as low as 3900-3800?
Old 02-02-2004, 07:51 PM   #8
TIMSPEED
TIMSPEED's Avatar
I weighed it on 3 different scales, and they've all said the same thing.
See Them Here
Old 02-02-2004, 08:01 PM   #9
low 84
low 84's Avatar
wow, check your sources on that one. my truck weighs no where near 4600. i would say closer to 3700
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-02-2004, 08:32 PM   #10
bigblock73
yeller
bigblock73's Avatar
Check this out...
1975 C-10 shortbed, 4640 pounds. Could the article have incorrect information?
Old 02-02-2004, 08:35 PM   #11
bigblock73
yeller
bigblock73's Avatar
how about this one?
76 Big 10 2wd stepside w/454...4320 pounds. Take off 200 or so for the BB and it is still above 4000..and it is a stepside (lighter).
Old 02-02-2004, 08:45 PM   #12
bigblock73
yeller
bigblock73's Avatar
OK, item #3...my trusty GM 1976 Light duty truck sales album..
c-10 swb V8, 3803...3645 with a 6 cylinder.
It sounds like the dealers album may be correct, especially if Tim weighed his truck three times...but then again, he thought he had a th350...then a th400...then a th350...
I will assume the magazine articles are incorrect.
Old 02-02-2004, 08:50 PM   #13
swervin ervin
You get what you pay for
swervin ervin's Avatar
Jeff,
I weighed my truck at the county landfill back in 1999. It weighed 3960 pounds with me not in it. I don't remember how much gas was in it. This was after I had removed the AC stuff. Of course I didn't have my aluminum wheels, still had the steel ralleys on it. I need to weigh it now. I figure it will be around 3900 pounds or less.
I don't think Tim's truck ever had AC and it also don't have a tailgate. So since the AC cabs are much heavier and the tailgate, I would say his listed weight is pretty close.
I believe I'll go by and weigh it again tomorrow if I don't forget.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-02-2004, 08:57 PM   #14
TIMSPEED
TIMSPEED's Avatar
Nope, No A/C or anything power except steering from the factory. Also removed my tailgate and rear step bumper, as well as ALL smog stuff, got aluminum rims and don't have any sound or heat shielding under the carpet...
See Them Here
Old 02-02-2004, 08:58 PM   #15
1FaastC10
1FaastC10's Avatar
i weighed my 82 C10 LWB with me and a buddy in it, just like Mike, at the landfill, and it tipped the scales at 4600.
1FaastC10 is offline   Reply With Quote
Old 02-02-2004, 08:59 PM   #16
low 84
low 84's Avatar
i'm going to have mine weighed fairly soon also but i have to find a place that has split scales and can tell me how much weight is on each wheel.
'05 1500 Crew Cab
RIP
Old 02-02-2004, 09:04 PM   #17
TIMSPEED
TIMSPEED's Avatar
If it stops raining tonight, I will take my truck over to the scale and take a picture of the truck on the scale, with the weight showing, for all to see
BTW: Thanks for posting that article about the 74 Jeff..FACTORY gas mileage with 3.07 gears, was 10mpg! Also, that article PROVES that 4.11's were available from the factory
See Them Here
