Old 02-02-2004, 11:07 AM   #1
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
700R4 Transmission mount
Hey All,
I'm installing an engine (350) and trans (700R4) out of an 1985 Chevy Suburban into my 1970 Chevy. I got everything sitting in the frame right now loose. How level should the combination be? Right now it is sitting lower at the rear. I think it might be too low. Can I use the original trans mount? I know I need to move it from where it was. I looked around the web and I found a custom 700R4 mount for around $180. I'm handy with a torch and wire feed welder and I should be able to modify mine whether I need to go up or down.
Anyone ever done this?
MJ
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 02-02-2004, 12:08 PM   #2
cdowns
cdowns's Avatar
you don't need anything special just the auto crossmember for the 70truck and a regular tranny mount (i used a pro-thane @ $25) the crossmember has to be in the backholes in the frame rails simple bolt in no torch or welding required
Old 02-02-2004, 12:11 PM   #3
cdowns
cdowns's Avatar
that's using the stock 70 engine mounts and towers
Old 02-02-2004, 01:04 PM   #4
onetoncrewcab
cdowns.
Thanks. I guess I did not notice another set of mounting holes on the frame. I'll have to take a look at the again.
You just might have clarified another problem I was having. I was using the towers from the 85 Suburban because I like the newer style motor mounts, but they weren't lining up worth crap. I think I can use them, but I will have to drill new holes and a spacer between the top of the mount and frame. The frame on the 70 is about a half inch shorter than the 85 frame. I didn't try the 70 mounts and brackets yet. I'll give that a try the next time I get to the shop.
MJ
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
Old 02-02-2004, 01:08 PM   #5
onetoncrewcab
One thing I forgot to add. The reason I was going with the later model mounts is because I switched the front crossmember to one out of a 1978 Chevy Suburban. I wanted the disc brakes out of it. Everything is bolting up pretty decent so far.
MJ
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
