Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 04-21-2001, 04:01 PM   #1
ThreeQuarter
ThreeQuarter's Avatar
Post Fan Shroud for 34" Radiator
I have run all over town looking for a fan shroud to go with my new 34" radiator and nobody has one--wrecking yards or dealers.
I'm replacing my 28-1/4" 2-core with the bigger 34" 4-core and the shrouds are different, along with the slotted mounting pads (GM calls them "insulators"). My core support will accept the 34" radiator, thta's not the problem.
Does anyone have a 34" fan shroud sitting around that will work with my 350?
'72 GMC 3/4 Longstep
'92 Chevy K1500 XCab LWB 350/3.73s
Aggieland, TX
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 04-24-2001, 11:23 PM   #2
ThreeQuarter
Post
The parts guys at Sterling GMC (top notch guys) figured it out today. Used a big block shroud and insulators. These radiators mount differently--they use metal brackets instead of just the plastic shroud.
The 350's fan doesn't reach all the way into the shroud but good enough I think. Might get a longer shaft fan clutch at a later date if it's a problem.
Now I only have one problem left ot solve: the radiator-ends of the engine oil cooler lines don't fit the big radiator. Kinda like one is metric and the other is std. Hmmm.
If you ever want to change your 28-1/4" radiator to a 34" just let me know. I have all the parts numbers. BTW, I spent $350 on a radiator and $100 on GM parts (shroud, insulators, brackets).
Aggieland, TX
Ben
