02-02-2004, 01:50 PM | #1 |
Fetzer Valve Technician
Rust Holes in Windshield drip rail
Anyone know what the best way to fix dime/nickel sized rust holes in the drip rail over the windshield? The rail isnt rusted out, just 3 or 4 holes in the valley created by the rail. Is there a patch panel or anything? The rust didnt go thru to the inner roof, so I am ok there. Any Ideas?
02-02-2004, 04:30 PM | #2 |
No patch panels are available for the drip rail and roof. Cut out the rusted areas and fab some patches, weld 'em in. The drip rail gutter is prone to rust when the orig. sealant is cracked. You probably should sand blast the gutter and reseal it with seam sealer. I have used left over scraps of patch panels to make small repairs like these. It might be a good idea to seal the metal in the gutter area with MasterSeries Permanent Rust Sealer or POR-15 (Allow it to run down between the seam) before you use the seam sealer to prevent future rust in the area.
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
02-02-2004, 05:39 PM | #3 |
My other Love
while you're at it, shave em off!
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
02-02-2004, 11:22 PM | #4 |
Clean out the rust and weld them with a wire feeder........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-02-2004, 11:28 PM | #5 |
My other Love
ya thats how i have been fixing rust on my Monte, theres little pinhole rust areas and i just weld a big spot and keep on welding the spot bigger till I fill the hole, but then there is usually a lot of grinding to be done
02-02-2004, 11:47 PM | #6 |
If you choose to weld use a piece of copper or bronze as a backer on the hole....allows you to fill the hole easier....
Forgot to mention that on previous post.
