Crank pulley question ????? HELP
I have a 69 air cab with 350. Pulleys are not aligning with w hat I believe to be oem pulleys. Questions.........is the crank pully 2 or 3 grove on an air truck? Mine has 3 but maybe I only need the 2 grove........I am trying to take it back to original after years of rigging.
It' fairly common to see a 2 piece lower pulley set in 69. So a total of three grooves.... .. the single pulley is for he PS and the double is for ac and water pump+ alt . You need a double groove water pump also.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
might as well post a pic
Howzit?!?
I had a similar problem and have a question about the pulleys in the picture. The one on the left looks like the long water pump crank pulley I took off of my 307 when I switched from the long pump to the short pump. Doesn't the water pump make a difference?
From what I learned on mine it does make a difference, but I wanted clarification cuz I ended up with chrome aftermarket pulleys. J
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
![]() Join Date: Sep 2001
I believe (and I might be wrong) the long water pump didn't come out until later in the '70s. You should have a short water pump on that 350 if you're going to stock, which means you may have to check those OEM pulleys to make sure they're correct.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
here's the picture that TX got .....this is what you won on e-bay or was it someone else.....DOHOO.....
Thanks guys. Hawaiian-J actually came by with pulleys and we think it's in the W/P pulley that is wrong. All others (crank, alt, P/S we believe will work.....so I'm off to get with a guy that had my old w/p pulley which is two groove and not the 3 grove like I have.........thanks to you all and a big thanks for Jason coming out in the cold to work through it............pretty cool temps for a Hawaiian. OH....I did not bid on any pulleys on ebay.........but maybe someone will feel sorry for me and ship to me.
Thanks again. |
Lets zoom in a little... well lets see,.. the stamped part number is 3923898... how bout that ..ITS A 68-71 SB LOWER CRANK PULLEY HOW BOUT THAT.:p thats what my 71 Chevy dealer part books says it is. Oh and the one beside it in the pic I posted above is part number and stamped 3755820... also correct pic of a ps lower pulley for a SB... which is good from 63-72 v8.
This auction on ebay is over but never sold...$15 for a set of ps crank and wp pulleys... good deal as far I'm concerned... not positive about the crank pulley on this one... would need a number on it to verify. Maybe contact him.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
#10 | |
Howzit?!?
![]() ![]() rage'nrat638, That's like the one he has, plus the add on for air. Thanks!
#11 | |
Re: Crank pulley question ????? HELP
The bigger daul groove piece turns the power steering. Everything works, except that my little stamped steel one for wtr/alt is bent. Now I deal w/ my friends offering me these 3 groove stamped ones that will not work for mine. Not sure if i should look out for another one like I have or attempt to "upgrade" to a more common setup. |
#12 | |
Noobie digging up a 5 year old thread....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#13 |
![]() Join Date: Sep 2005
wow i just read a 5 year old post
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#14 |
Er...............Congrats????????????????? Five year post or not, I could still use the info. I've found a short water pump single groove pulley online. I'm thikin' this is what I need. |
