Old 02-03-2004, 12:51 PM   #1
dubie
dubie's Avatar
Question Flipping front clip
I have seen a couple pics of at least 2 board members that have done this mod on their 67-72's over the past couple years. Does anyone know where I can find some info on this? I can vision how to do all of it in my head, but the only part I get stuck on is where the fender pieces meet, and how it's latched.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-03-2004, 01:01 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Flipping front clip
Originally posted by dubie
... but the only part I get stuck on is where the fender pieces meet, and how it's latched.
Red Green says "duct tape"
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-03-2004, 01:02 PM   #3
dubie
dubie's Avatar
how bout some velcro
Old 02-03-2004, 01:05 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Good stuff! Made in NH too!
Old 02-03-2004, 01:07 PM   #5
dubie
dubie's Avatar
Hey Jeff, you ever seen how these front clips are done?? I'm very curious to see how they work and if there is any rubbing noise when driving. I wish crazy longhorn had his own website with some pics. I see he hasn't even posted since November
Old 02-03-2004, 01:10 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
No I haven't but I've been trying to remember who has one so I can post a serious response for ya. At least my incessant nattering keeps you TTT.
Old 02-03-2004, 01:14 PM   #7
dubie
dubie's Avatar
another fellow board member sneeakysnake also has one. I have PM'd hime but hasn't read it yet. This is a pic of his
Old 02-03-2004, 01:26 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Dubie,
I'm not sure what you are trying to accomplish with a "tilt front end". I can tell you a bit about how its done. Normally a small car or truck hood latch is used at the center of the firewall.
If you just want something different, why not reverse tilt the hood intead? Its much simplier to do, and the end result is much cleaner too. When everything is closed you can't tell it's not stock....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2004, 01:44 PM   #9
MMGOODIE
I love doing it topless
MMGOODIE's Avatar
if you don't mind going fiberglass
you can go here
http://www.usbody.com/67-72%20chevrolet%20truck.htm
Mikey
"If you can read this, thank a teacher;
If you are reading it in English, thank a soldier."
MMGOODIE is offline   Reply With Quote
Old 02-03-2004, 02:45 PM   #10
Bowtiefreak
Bowtiefreak's Avatar
You may want to give Ed @ MOTHETRUCKERS a call. I believe he has done this before also.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 02-03-2004, 02:48 PM   #11
dubie
dubie's Avatar
Originally posted by N2TRUX
Dubie,
2 reasons
1. It looks cool as all hell
2. It gives you better access to your engine compartment and that's a bonus when you put your small block in the Inline 6 position.
I know material wise , it only costs about $100, but it takes quite a bit of time to get it right. I have a spare front clip to practice on that is basically scrap, so if i screw it up, it's going to the dump anyways.
Old 02-03-2004, 03:08 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Dubie, I thought of this also for my 4wd. I was think about running a 2wd fan shroud and moving a modified core support closer to the engine to support the radiator(hoses will be shortened also). Then with the whole front (core, fenders, modifed inners and grill) tilt forward with the hinges mounting to the core support. cut the back the fenders as needed and mount to the cab. Of course cut out what is not needed from the fneders and inners with it all being welded together. I'll also have a front clip to "experiment" with in March after I get the 71 from Dean's brother. We'll have to compare designs. I was thinking of mounting the battery under/in a bed side.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-03-2004, 04:14 PM   #13
Alexis
Member since 2000
Alexis's Avatar
I know Crazy Longhorn did it to his........but i haven't seen him for a while.
Alexis is offline   Reply With Quote
Old 02-03-2004, 04:26 PM   #14
dubie
dubie's Avatar
Ok, my idea is a bit different from yours Jim. I imagine leaving the rad support where it is, but cut away on either side of the rad so the headlight buckets are unattached from the rad section and are ready to tilt. This way your rad and hoses stay put and there is no chnging in length. Then you weld a pin hinge on the bottom of the rad support to get your rolling forward action. You totally eliminate the inner fenders (on a 2wd) and cut the outers where they need to be cut. Extend your headlight wires and attach 2 guide wires to hold you front clip when it's open, or install some suspension cylinders to open it. It all seems to make sense when I have it all drawn out, but I have never seen one in person on a truck.
Old 02-03-2004, 05:55 PM   #15
meathead95
computer illiterate
meathead95's Avatar
didnt berns68 (or something to that effect) just do this same mod?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-03-2004, 10:32 PM   #16
Slams_58
TTT
Hopefully someone who has done this will reply and give us some insight
Slams_58 is offline   Reply With Quote
