![]() Join Date: Jan 2001
brake booster question
I know that Delco and Bendix master cylinders and boosters are different on 1/2 ton trucks, but is this true on 3/4 trucks ? In particular I have a Delco booster with rod and a master cylinder made by Bendix. They seem to fit together ok, but I'm wondering if I'll have problems with the rod length. Any opinions would be appreciated. If it makes any difference, it's on a K20 with axles off a 78.
Bernie |
My other Love
hmm well as far as i know the boosters are the same, just depends on what type if master cylinder you have in front of it, I dont think GM would have made two different boosters for different master cylinders. The only difference in boosters I have seen is for different GVWR's
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
its all about the +6 inches
The pushrod is adjustable anyways.
Thanks for the replies. I thought it was only the pushrod that connected to the pedal that was able to be adjusted ??
Bernie |
ON the booster equipped trucks (at least the two 1970 ones I have had) has an adjustable pushrod in the booster. If you remove the master cylinder and pull out the rod, it is a 2 piece rod that is threaded together.
Thanks, I'll look tonight.
Bernie |
Designated A-hole!
Mine is adjustable (70 GMC).
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
