Rear Disc Rear end
Has anyone used or does anyone know if you can use a rear end from a 2000+ chevy truck with rear disc brakes as a swap to our trucks?? It is a leaf setup and thats what I have now. I dont want to do a bunch of fabracating. Would it be easier to just buy aftermarket setup for my present rear end?
Thanks, 70short/step |
Florida Key's Member
rear disk
there are kits to add rear disk to our old rear ends. that saves all the fabrication work
Craig Wood 1972 SWB Chevy Cheyenne 4X4 Restored stock except 454 (481 cu. in. now) most options Available pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528 Come to florida and visit www.Paradisewatersports.com |
Project Money Pit
does that truck have anti-lock brakes? 5 or 6 lug? rear end conversion kits @ $ 140
For sale: GMC rad support $50, L/F 69-72 fender $50, (1) 69-72 & 67-68 Chevy hood $50 ea.,1 disc brake spindles w/ calipers and rotors $ 25 WTB: (1) R/F inner fender. OR will trade |
Its 6 lug. Not sure if its antilock or not, But that shouldnt matter.
should it?? I havent seen the truck, just the rear end. |
Hello,
Don't know much about new truck rear axles as far as width goes, however, you could take it to an axle shop, have them cut off all the brackets and cut the saddles off your coil spring axle and weld them onto the new axle at the correct width and angle and voila! Cost about $65-$75 here in the Dallas, TX area. I have done this with Camaro axles and it worked fine. Don't know about any of that anti-lock stuff though. Ernie
72 2WD Blazer 68 SWB Fleetside 67 SWB Stepside 2005 Chevy 1500HD Crewcab 56 Chris Craft Mahogany Runabout Looking for 36 Chevy 1/2 Ton P/U Project |
