02-04-2004, 01:11 AM | #1 |
Embrace the Redneck
Let's beef up a 250
Guys I want to keep the 250 I6 in my pickup. its a 67 c10 w/ 3 on tree.
I want to get: > tube headers of good quality (I've seen a few go on eBay). > 4 bbl Intake and carb. (I've seen a dual carb intake, what cha think?) > and electric cooling fan and maybe h2o pump. What do you guys think? I want to be able to at least compete with a stock V8 but not loose that reputation the 250 has for "going Forever" . Let's hear it guys. I'm might be rebuilding one of these. I have an extra motor to do this with!! Thanks, Steven
'01 Camaro Son, you just can't get there from here... |
02-04-2004, 01:19 AM | #2 |
TURBO CHARGE IT......
100 SHOT |
02-04-2004, 01:31 AM | #3 |
Want to make a small fortune?? Start with a large fortune and rebuild/modify a Chevy 6
Stepsides look like real trucks! Smitty |
02-04-2004, 01:34 AM | #4 | |
Embrace the Redneck
Plus do you have a bigger size of that pic? and where did you find it?? thanks, S
02-04-2004, 01:53 AM | #5 |
Don't waste your money. Either live with the 6 for what it is or pull it and put in an 8. You will never make the 6 equal to the 8 and the parts to improve the 8 are much more plentiful and much cheaper.
I have had a 250, a 292 and a 350. I like my old 292 well enough but if it has to be rebuilt, it is going to get swapped for a 350 real fast.
1968 Chevy - 292 with a powerglide |
02-04-2004, 01:56 AM | #6 |
I mean it costs much more to rebuild and/or modify a six than say, a 350. I know, I've been there-done that. Parts are like double or more for a six. Don't take my word for it, check it for yourself.
The picture is from my camera--engine is in my Coupe--love the engine-hate the cost! BTW--all assembly done by yours truly.
02-04-2004, 02:00 AM | #7 |
I had a 250 once in a 68 chevelle. A company called "Clifford" out of california (I think) makes a bunch of stuff for the 250. They may still be around. Isky makes a nice cam for the 250 as well. If you change the cam out you will likely need to change valve springs as well. Good luck !!!
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
02-04-2004, 07:44 AM | #8 |
Cliffords is the main 6 gurus on speed. But like was mentioned, it cost a lot more for the 6 parts than a 350. If your doing it for power, then get a 350. If your doing just to be different, then check out cliffords. Most HIPoi parts are double what you can get for a 350.
02-04-2004, 08:56 AM | #9 |
smitty62,
Is that an Offenhauser intake manifold? Like the picture of the old Chevy, noticed what looks to be a stop light on the building in back of her..........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-04-2004, 10:54 AM | #10 |
On my 292 it has a lump port head with 2.05 valves and minor port and polish 700.00, 63 forged steel crank 300.00, H beam rods- forged pistons 800.00, cam lifters screw in studs guide plates springs 350.00, dynamax headers 150.00, ceramic coating 150.00, Offy 4 bbl intake 200.00 match porting 75.00, custom built 735 cfm carb 850.00, ARP studs 120.00, machine work boring decking stress reliving etc 450.00, custom built HEI and wires 200.00, blowing away 5.0 mustangs with an old truck PRICELESS!
For the money a small or big block is way cheaper to build! ! If I havent scared you off I have some used Offy 4 bbl manifolds 390 cfm carbs and other 6 cyl parts for sale. Also 4 bolt main 350 short blocks 010 nickel 75.00 020 nickel 100.00 030 nickel 300.00.
Rest in Peace Ed. Thanks for all the good times. |
02-04-2004, 11:23 AM | #11 |
For info and pics on building up inlines go to www.inliners.org
There are some great tips and pics of inlines there. I was going to build up my inline 6 but after weighing the cost and the power I wanted to achieve in the end, I built a 350 for around $2000. I have 2, 250's sitting in my stock right now and I still plan on building up an inline for the next project .
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-04-2004, 11:53 AM | #12 |
Bluebeard--no, believe it or not, it's an Edelbrock! Found it in so-so condition on Ebay--rebuilt it and I'm delighted ith it. It's heated the same as a stock manifold. Offenhauser has a P-poor system of heating--either with heat tubes or hot water. I love the sound of a six, mine is a bored .060" 235 and has a great split manifold and Smitty's--just like 50 years ago! But the power/cost ratio is way out of line.
BTW--the air cleaners shown are for sale--4 barrels modified to fit the single barrel carbs--$30 shipped. I'm now using 1940 Chevy truck air cleaners with Kohler air filters! The Red Baron
02-04-2004, 05:40 PM | #13 |
Everything that u are looking for can be found in the JC Whitney
the headers, the 4 bbl intake, and also a holley 530cfm carb to with that 250 inline, i want to do the same to my 250 for my 67 GMC shortie. Check it out. Keep on trukin! |
02-04-2004, 05:47 PM | #14 |
JC Whitney Truck Catalog
02-04-2004, 05:55 PM | #15 |
Out draggin'
You CAN make a six run.... A freind of my dads is running a 301 Jimmy I-6 in a 57' Chevy 2 dr sedan. The car is all steel and running a 4 speed. He runs the car in the Nostalgia Drags sometimes(he has owned/raced it since the early 60's with this setup). He was an IHRA Natl' Record holder for years with that car running at Englishtown Raceway Park.
I have personally seen that car pull the front wheels 2 feet plus in the air and carry them for the first 40-60 feet. Sounds neat too!!!
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
02-04-2004, 06:57 PM | #16 |
The LuvShack Garage
67 CAMARO IN HOT ROD A FEW YEARS BACK WITH A 292 AND A
3 SPD. IT RAN LOW 11'S IN THE QUARTER. NOT TO SHABBY.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-04-2004, 08:27 PM | #17 |
I for one did NOT say you couldn't make a six run! I said it's too expensive for what you get. Hell, I've been running sixes since 1951--yes, I'm old, but not senile. You put $3000 into a Chevy 235 or a 292 GMC (forget 230's and 250's--poor design--you will find very little in the way of actual speed equipment for them--235 is a much better engine--292 GMC better yet) and you'll have sweet running and sounding engine-a lot of fun.
Put the SAME $3000 into a SBC 350 or 383 and it will run the A$$ off the six! If you want to be stubborn about this, feel free--but do your research.
Stepsides look like real trucks! Smitty Last edited by smitty62; 02-04-2004 at 08:31 PM. |
02-04-2004, 09:23 PM | #18 |
02-05-2004, 03:36 AM | #19 | |
Out of the carpool lane.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
02-05-2004, 06:50 AM | #20 |
I ran a 292 on my '68 C/10 stepside [built in '77] to 2002. About 250,000 miles. It was bored .030 over, stock or heavy duty build. I ran a Holley 4 Bbl 390 cfm on an Offy intake, Clifford headers, Mallory coil, stock points ignition. These components would work on a 250 as well.
I'm currently in the process of installing my rebuilt other 292 block. Hopefully when the rainy season is over. Yes it is spendy, but that solid feeling of torque is worth it. V8s just don't last as long. Too many moving parts. I've killed a 327 and a 454 in only the last 10 years. If you factor in the longevity aspect, it evens out.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-05-2004 at 06:54 AM. |
02-05-2004, 01:31 PM | #21 |
If you will read my posting I said a "GMC" 292--not a Chevy. Very hard to come by.
02-05-2004, 01:46 PM | #22 |
A start
This is what I am starting out with for my 250 inline.
02-05-2004, 02:11 PM | #23 |
And this
headers
02-05-2004, 10:02 PM | #24 |
I have a good used 4bbl Offy intake for 125.00 and new dynamax headers for 169.00 if interested.
