02-04-2004, 02:21 AM | #1 |
Member since 2000
B & M Shift Improver kit #70239
20 dallors plus ride. From SummitRacing.com "Improve shifting in a snap. GM: 1982-93 TH-700R-4, 4L60, B&M shift improver kit Installing this B&M Shift Improver Kit is simple. You just drop the transmission pan and take out the valve body and stock separator plate, put the B&M shift improver kit's separator plate in its place, replace the valve body, and bolt up the pan. If your kit requires some other modifications, they'll be just as easy. Each kit has two stages: RV/Towing and Street/Strip." |
02-04-2004, 02:21 AM | #2 |
Member since 2000
one more picture
02-05-2004, 05:05 PM | #3 |
Member since 2000
TTT
02-11-2004, 10:53 AM | #4 |
kit
still got the kit and how much for the ride to 77433?and i think it will but will it work on 94 your ad says upto 93 i have a 4l60e....thanks
02-11-2004, 01:08 PM | #5 |
Member since 2000
sorry, i thought this thread had died. The item has been sold.
You're looking for shift kit BMM-70360 |
