Old 02-04-2004, 11:43 AM   #1
krue
Designated A-hole!
krue's Avatar
Angry Tranny leak
I have determined that my tranny (Th-350) is leaking fluid from the general area of the dipstick tube. Is there anything else beside the tube O-ring that I need to replace?
Thanks, Krue
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-04-2004, 11:55 AM   #2
kwmech
Pan gasket and filter while your at it.
Old 02-04-2004, 11:59 AM   #3
krue
Designated A-hole!
krue's Avatar
Been there done that 3 times trying to track this leak down. Have a rubber gasket on the pan now. I can finally see fluid around dipstick.
www.daveramsey.com
Old 02-04-2004, 12:07 PM   #4
Olden Days
Living In The Past
Olden Days's Avatar
go the chevy parts house and ask for the replacement dipstick. the end that goes in the trans will be smaller diameter than stock and will come with rubber boot to replace stupid leaking O rings. good solid fit, no more leaks (from that part anyhow).I paid less than 20 bucks awhile back for this.
Olden Days is offline   Reply With Quote
Old 02-04-2004, 02:34 PM   #5
krue
Designated A-hole!
krue's Avatar
Thanks, I am going to try anew O-ring and if that doesn't work I will get a new dipstick,
www.daveramsey.com
Old 02-04-2004, 03:27 PM   #6
superfly68
superfly68's Avatar
i am in the same boat. been told i need the rubber skirt! also going to throw away the chrome POS one i bought and buy an original dipstick.
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 02-04-2004, 03:41 PM   #7
MMGOODIE
I love doing it topless
MMGOODIE's Avatar
I was always taught that if it leaks then every thing is all right. if it doesn't leak then you have a problem.
Mikey
"If you can read this, thank a teacher;
If you are reading it in English, thank a soldier."
MMGOODIE is offline   Reply With Quote
Old 02-04-2004, 04:50 PM   #8
1972C10
1972C10's Avatar
Silocone the dipstick in addition to the o ring thats the only way i could get mine to seal.
the newer style dipstick with the grommets are 10 times better about sealing up than the o rings. you can find them just about anywhere for cheap . Just find a newer car or truck late 70s mid 80s with a th350 . you can get a new replacement dipstick with the lock down dipstick for around 20 at a local transmission shop here.
1972C10 is offline   Reply With Quote
