Adding power brakes?
What would be needed to add a power brakes to a '69 C-10 with manual drum brakes? The brakes are in good condition otherwise. Approximately what would the parts cost (new)?
Thank you. |
You need a Power Brake booster. You might think of buying a Power/Disc kit from GMC Pauls or one of the other vendors. Comes with everything needed to do the swap. Ebay is another source for finding a booster.
Alex 1971 Lil' Red 350 SBC 700R4 |
OK, so if I read GMC Pauls catalog right I would need a kit that includes: power booster, & dual valve master cylinder, mounting brackets and brake pedal to booster push rod for around $250.00, right?
'69 C-10 LWB, 350, TH350, posi-traction |
Yes. I would get the kit with the 9" booster, believe it's $269.00. Not sure if you are going to need the porportioning valve as well. Call or email Les and he will set you up:
GMCPauls Truck Parts Phone-(765)344-2906 / Fax-(773)-442-0103 8778 East Old 36 Road / Rockville, IN / 47872 Email- robbinspd1199@yahoo.com Very good people to deal with!
Designated A-hole!
Just to upgrade with power and not disc brakes you just need the booster and master cylinder, you can use your existing prop valve. Cost me $20 or $30 from a board member. Works pretty good until I scrape up the dough to go disc.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Question?? Im about to do the upgrade myself should I go disc and drum manual or should I go disc and drum with power?? any thoughts?
Get the power booster if you can afford to do so. You won't be sorry.
Pronounced "Pew-al-up"
I did mine for $50. I bought the bracket and the booster from
a member, and used the same proportioning valve. It is a worthy upgrade!
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
Ive been looking at the kits at GMCpauls The prices seem to be good. Has anybody here dealt with them? Not trying to ? them just asking?
I have bought many things from GMC Pauls. They are great to deal with and very helpful. Even on a return they will work with you. Nothing but stars for GMC Pauls. Ask for Les.
