For all those with that "mystery rattle".
Well,
I was breaking in the new cam in my REBUILT 305! LOL.......I like 20 MPG remember?... and I heard this rattle which I had been hearing through the 305 before I did the re-build, the 350 that was in there for a bit and is now in the dump, and two different transmissions. I am kind of one with all the grinds and growls, bumps and rattles that just seem to go with these old trucks but I do have a pretty good idea of what they come from and so they never get to me much. This noise had been bugging me for a while though because it sounded alot like the flexplate rattling against the dust cover or a loose converter bolt or something and I kept checking but found nothing amiss down there. Well while I was breaking in the cam I was sitting in the drive in neutral with the door open and wouldn't you know it but there is this sound again consistently at 1700 rpms. I put my head down alongside the cab to listen and out of the corner of my eye I saw the gas tank filler door vibrating. I let the throttle drop down to 1500 and sure enough it stopped. back up at 1700 there it was again. So before you go replacing your next torque converter take a look at the filler door and you may end up saving yourself some time and $$$. ![]()
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
You get what you pay for
![]() Join Date: Dec 1999
You get 20 mpg from a 305?? How??
Mike 1985 Chevy C-10 |
I wanna know that as well, Mike. i may be interested in going back to a 305 (not really)
2004 Silverado Crewcab (Dark Spiral Gray) |
LOL... the way I drive.
I could put a block off plate over the secondaries and never know the difference. Also overdrive and 2.73's help. The carb came off my 86 California truck. I think that has something to do with it as well. As much as you love to hate all the electronics and emissions crap (and believe me I do) it does make a difference. Remember those days mike?
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! Last edited by 86SILVERADO; 02-04-2004 at 10:56 PM. |
i get atleast 15 in the city and 17 on the highway. gotta love all thoes vacuum lines!!
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
All country roads around here. 35 to 55 speed limits. I pretty much just get on those roads and cruise. I don't think I have ever driven my trucks into the city once. That's what the volvo is for.
I am a volvo fan as well. Have had a couple 240's and now the 1980 diesel 264.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! Last edited by 86SILVERADO; 02-04-2004 at 11:16 PM. |
About the vacuum lines,
That is why I bought the 67. Now that is how an engine bay should look. Ahhhhhhh
Professional Grade
I hooked all my vac stuff back up too, but I organized it all, and it actually doesn't look all that dirty at all. That looks like a Carter Q-Jet, the same as the one on my truck, mine needs a rebuild, but works pretty good, gives a real kick when you open those secondaries!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
