Old 02-05-2004, 11:33 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Sway bar question?
Ok, experts help me out here. I may have a chance to get a front sway bar for my 77. The catch is it's coming off of a 3/4 ton 4wd. I know the 3/4 ton part is good because it has the larger bar. My question is are the 2wd and 4wd bars the same?
I know the links that connect to the axle are different, and I assume the stands on the frame are taller too. I'm not worried about any of that because I can buy all that new.
I need to be sure that the bar itself is the same. Does anyone know "for sure"?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-05-2004, 11:56 AM   #2
gldevall
gldevall's Avatar
Why not just buy a complete new bar? I think you can get one from PST for about $150 with all of the bushings and mounts.
http://www.p-s-t.com/
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 02-05-2004, 12:07 PM   #3
Jonboy
Slots go on anything!
the 4WD bar is completely different. It mounts to the u-bolts on the front leaf springs. The bar mounts horizontally on a square pad instead of using links. You might look into getting a 2WD aftermarket bar.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-05-2004, 01:37 PM   #4
Izzy
Trucker.
Izzy's Avatar
It'd be best to get a 2wd 1 ton bar since they mount the same just have bigger diameter "D" mounts.
Izzy is offline   Reply With Quote
Old 02-05-2004, 01:41 PM   #5
Tom
driving is in my blood
Tom's Avatar
Because for a total of $50 I got a 1 1/4" sway bar with poly bushings from the junkyard and PST :p
Old 02-05-2004, 02:44 PM   #6
78SilveradoSWB
78SilveradoSWB's Avatar
The 2WD bar is different than the 4WD bar. You need to find a 3/4 or 1 ton 2WD one in a bone yard or on Ebay. My C-10 had the smaller dia. swaybar and I upgraded to a 1 1/4" one from a 1 ton which I bought on Ebay for $25 and I bought some Energy Suspension poly bushings/brackets and stainless steel hex bolts. Works great!
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 02-05-2004, 03:47 PM   #7
Russell
Professional Grade
Russell's Avatar
My 76 2wd 3/4 has a front sway bar, I can take a couple of jacks and axle stands with me next time I go and get it for you, not too sure when I would be headed out though...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-05-2004, 04:26 PM   #8
78chevstepside
78chevstepside's Avatar
I recently put a 1" 1/8 sway bar on the front of my 78. I got mine out of a u- pull-it wrecking yard. Some new bushings, cleaning, and paint and its good to go. The upper brackets are a little hard to find new if yours didnt come equiped from the factory. Mine didnt but the holes where pre-drilled .. I bought the upper brackets new from chevrolet.
78chevstepside is offline   Reply With Quote
Old 02-05-2004, 08:23 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Wow! Was I off base here. I don't know why I was thinking the bar itself was the same. OK, so that won't work.
Russell I really appreciate your offer, but I think no matter how we shipped it it wouldn't be cheap. Texas and Canada aren't very close anymore
I guess I need to get my butt to a local salvage yard and snag one. Problem is I don't even know where one is in my area. Hmmm? Wheres that phone book....
Thanks for the info guys....
