Old 04-01-2002, 08:17 PM   #1
Dandeluxe
Dandeluxe's Avatar
Question gas gauge troubleshooting
i put my dash back in after swapping from a reg. gauge dash to a dash with a tach in it. but now i found my gas gauge doesnt work. should i try putting in the other gas gauge that worked in the other dash or is there a way to troubleshoot it. maybe the circuit board is bad. ??????
1969 cst swb 350/400 th DANNY C. ddclux@aol.com st. louis mo.
for pic.s go to http://community.webshots.com/user/dandeluxeGO TO Fotki. com for public pic.s under DANDELUXE
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 04-01-2002, 08:26 PM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Find the brown wire that comes out of the upper right corner of the fuse box. That's your fuel gauge wire. Make sure it's connected to the fuse box.
Now pull the wire off the sender at the tank. Your gauge should go to way over full if it's working (with the key on). If you short the wire to ground, the gauge should go to empty. If it won't exhibit either of these tendencies, pull the connector off the back of your new instrument panel and clean it and the contacts on the flex-circuit. Don't scrape them but use a soft pencil eraser instead. If all else fails, try swapping just your old fuel gauge back in. It might just be toast, but that isn't too common.
[This message has been edited by 71GMC_3/4T (edited April 01, 2002).]
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 04-01-2002, 09:24 PM   #3
Tim Christian
Tim Christian's Avatar
Question
Does it read full or empty?
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 04-01-2002, 10:31 PM   #4
Dandeluxe
Dandeluxe's Avatar
Thumbs down
Tim, it reads stuck at between 5/8 and 3/4
Old 04-01-2002, 10:34 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Then most likely you are not getting voltage to the guage its self. The brown wire is kinda like the ground...the more ground it gets, the more the needle moves. Howeve, if it is getting no power, the needle won't move no matter what you do with the ground.
Pull the inst panel and look at the printed circuit. I had to repair mine on the GMC...pretty easy really.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-02-2002, 02:41 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
you might check an make sure the printed circuit is the same beween the 2 panels, I've never seen a tach dash, but they might use a different plug with contacts in different places.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
