Pesemistic Optimist
Fan high speed
The high speed on my blower motor does not work in my truck. I have heard of the fan relay going bad or a bad ground. The ground looks good so is there any way to test the relay or do I just have to buy a new one? BTW the truck is 1/2 tore apart so I don't have any battery power but stuff sure is easy to work on.
![]() Thanks for all the help, without this board I'd be rich and have alot of free time. ![]() Dan. |
you could bench test the relay and see if power comes out where it should!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Pesemistic Optimist
And how would I go about doing that?
Dan. (electrically challenged) |
I by-passed all the hoccus poccus !
Just find the wire which makes the fan go on high and hook up a toggle switch from the fuse box. A high is all you need! ![]()
Wiseass secured himself a BAN
Mine never worked. I even took the relay apart and the switch. Checked all the grounds and still nothing. DO NOT hook it up direct like ^ he said. You will fry the fan motor in due time. You may want to check the coils on the passenger side. There should the a thick coil and a thin coil. The thick coil is for high speed and the thin coil is for low speed.
20' Daredevil (Ret)
![]() Join Date: May 2003
Does your fan work on low and medium speed, just not on high? Mine did that once - it was just a bad fan speed control switch.
"Ochre Ogre"
first off, A/C or not? A/C has a relay, non-a/c doesn't. The coils that were mentioned are for low and medium speeds. When it is on high it bypasses the coils all together(they are called resisters I believe).
If non-a/c I would start by checking the ground strap at the blower motor. Then move to the switch on the speed lever. They are known for going bad, usually a loose rivit or bad contact inside. I usually take it apart and fix it but the parts are cheep so you can replace it too. If it is an A/C truck then everything above applys plus you have the relay on the side of the air plenum, under the glove box. It has a ground wire that could be off or making a bad contact and they tend to go bad too.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
its all about the +6 inches
Running power directly to the motor will do it no harm at all. That is what a relay does.
U bet 10 years trouble free on/off!
a relay controlls a steady 12 volts. the resistors bring the voltage down accordingly, hence the low and medium speed.
yeah, but how's it wheel? |
