02-05-2004, 03:00 PM | #1 |
rearend I.D. for speedometer correction
rearend has GM 69 stamped on it, tires are p275/60/15 with th350 tranny. any help would be appreciated. thanks.
02-05-2004, 03:08 PM | #2 |
1FINE69
Go to tci transmissions website they have calculators for the proper gears and really good prices from what I can tell.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
02-05-2004, 03:09 PM | #3 |
Formerly yellow72custom
If you are asking what the ratio is, proably the best way would be to pop your rearend cover, and stamed on the ring gear is the ratio. 41-10 is 4.10, 41-11 is 3.73, and 43-14 is 3.07.
I reccomend this because your rearend fluid poralby hasn't been changed in many years. And it is a simple job, besides the awful smell of gear oil.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
02-05-2004, 04:01 PM | #4 |
yes im looking for the gear ratio on the rearend, whats the common stock ratio for a 71 swb. thanks
02-05-2004, 04:09 PM | #5 |
depends on the engine and transmission. what engine do you have?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
02-05-2004, 04:15 PM | #6 |
originally had 6cyl. 250 / powerglide, just installed 350 crate/ th350 in v8 position.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
02-05-2004, 04:20 PM | #7 |
It would almost certinally be 3.73 then. Was standard in 6-cylinder trucks. Unless it says different on the glovebox option sheet, or the rearend has been swapped out sometime in the past.
