Mudslides 'r my specialty
15X8 Rallys rub 3" Spindles?
I know this has been covered many times over, but I always get different remarks from people.
I want to run 3" drop spindles with 15X8 stock Rallys. Will they rub? If you say they don't, then what spindles do you have? Does the lower control arm rub the wheel or the tire? Can I simply run a wheel spacer to push my wheel out a bit more? Are there 15X6 or 15X7 stock Rallys that have less backspacing that might work? I plan on running 225/75-15s for a short time. Eventually I will get 225/70s or 245/60s... Thanks, Brandon
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
Insert Witty Text Here
When I asked that same question, I was told that they can rub the wheel where the weights fit. Several people said they fixed the problem by grinding off part of the lower control arm. I was not comfortable with that, so I chose to go with Western Chassis 2.5 inch spindles.
I was also told that the 3 inch spindles also will sometimes cause the wheel to rub on the caliper, but I have seen that posted a lot less than comments about the LCA. Slonaker |
yeller
my 15x8 truck rally wheels and 3" Bell Tech spindles rubbed. I purchased Camaro/Vette style Rally wheels, 15x7, with one inch less back spacing and that solved the problem.
I do not recommend spacers. You can always shave a little off the control arm, that will solve the problem too.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
The full convertible guy
![]() Join Date: Jul 2001
I am running 3" Bell Tech spindles and 1" springs on my 75 Jimmy with 15x8 rallys and I have never noticed any rubbing. It has been lowered for 6 years or so and I do not recall doing any grinding but then again I am getting old and forgetful.
![]() ![]() I may go out tomorrow to check to see whether we did grind any but I do not recall doing so. Sorry to cloud things up more. ![]() Brad
2012 Kawasaki Vaquero (Lime Green) 2000 BMW 740iL 1995 Chevy ECSB riding on air 1975 GMC Jimmy 2WD lowered 4/6 1972 Chevy Trazer soon to be roadster 1965 Mustang 289/3 speed (friends dad bought it new) 1964 Chevy C10 (dad bought it new) |
I have 3" Belltech spindles with the stock springs. I tried to install the stock 8" ralleys and they rubbed real hard on the lower lip of the lower a-arm near the ball joint.
I used 6.5" Ralleys from a fullsize van. They had the same backspacing as the 8" wheels, but seemed to have a different profile that didn't rub as hard on the a-arms. I ground some off the lip of the a-arm, but it wasn't extensive. The 6.5" wheels also gave me plenty of clearance between the inner fender lip and the tire sidewall. I put 255/60/15 tires on the front and 275/70/15 on the rear. This gave another 1" drop on the front. Dave |
been here longer than Liz
When I had the 8" ralleys, mine didn't rub. That's seems to be a rarity though.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Thanks for the info....
