Old 02-05-2004, 04:27 PM   #1
PureChevy
PureChevy's Avatar
how much HP with new intake and carb??
I have a plain jane 350 in my truck and am looking for some ways to get some more power out of it. Right now it has heddman headers with a true dual exhaust and magnaflow xls. I was thinking about a edelbrock intake and carb. What kind should i get and how much Hp would i be looking at gaining. Is there anything else i should do before the intake and carb that would help?
1972 k10 4x4 LWB (Sold in 2005)
PureChevy is offline   Reply With Quote
Old 02-05-2004, 06:15 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Maybe 20 Hp, I would Upgrade to HEI with a good tuneup. If you are like most of us seeking more power you will want to upgrade the cam eventually also. My 2 cents....
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-05-2004, 06:17 PM   #3
PureChevy
PureChevy's Avatar
how much $$ am at lookin at for the intake and carb, compared to the Hei setup? Also, later with a cam, what kind of gains am i lookin at there?
Old 02-05-2004, 06:37 PM   #4
griesel72
griesel72's Avatar
I bought an intake and carb (performer rpm intake and a 750 electric choke, and got a free chrome air breather) all as a package deal and i paid right at 450 shipped.
I also bought a accel dist, cap, ignition module and super coil and paid right at 200.
Hope this helps you out.
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 02-05-2004, 06:38 PM   #5
jorgensensc
jorgensensc's Avatar
I say that HEI should be your first step. Worry about the intake and carb after you have good spark. My .02
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-05-2004, 07:24 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
What he said, along with the tuneup. A new carb really won't improve over your stock Q-jet if it is functioning properly. Q-jets are great carbs when they work well, and if yours is fine i would keep it. An intake might add 15 or so HP, but i am by no means a dyno expert. And of coure a mild cam would also help out.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-05-2004, 09:40 PM   #7
Bowtie67
Bowtie67's Avatar
Post
Depending on engine combo you have, Heads and such, if this is a run of the mill 350, low Compression engine your best bet for more performance will be Cam & Lifters, Intake & carb on a totally stock motor, maybe 10-12, and my self I would much prefer the QJet carb. The HEI won't really help in adding HP but will help as far as better tunability, Junkyard Distributer should be around 35 - 58 bucks. If these are the stock low compression, everyday cast iron heads, look at a set of either GM Vortec or the GM Fast Burn heads, not real expensive $500 - $600 and these will help, should get a far better rush with these then intake and carb will. For a cam with a little more enthusiasm and keeping a relatively street driving capability try Comp Cams XE 256 or XE262 . Just a not on cam selection it is what you have for the rest of your combination that count on what cam you need. Flat tappet Cam & Lifter kit should think less than $150.
Bowtie67 is offline   Reply With Quote
Old 02-05-2004, 10:30 PM   #8
super72
super72's Avatar
Been there done that. Best bang for my buck was the HEI. It was so much better after that. Then came carb, intake, and finally headers and exhaust. The real difference in power came when I put new heads and a cam. Then she was ready to roll.
super72 is offline   Reply With Quote
Old 02-06-2004, 12:19 AM   #9
Kenneth Brown
If its street driven only and your not trying to turn max rpms then I would look into another set of heads. The HIPO (ya right) 305 heads (casting # 416,601, and one more I can't remember) have 58 cc chambers and will definetly bring it alive. You will probably need to run 89 or better octane but its worth it. You can find these for as little as $50 a set. Add another $30 for a gasket set and your ready. After that I would look at the cam. If and when you decide on a cam stick with something small. Look for a lift figure under .480 and a duration (at .050 lift) no more than 214 degrees. This will give a nice sound and increase power tremendously. It will even help with fuel milage if you usually turn 3000 rpms or so at cruising speed. A stock intake is actually pretty good. A good running quadrajet is a great carb, its better that the holley's and edelbrocks if its tuned and operating correctly. Just my 3 cents on the matter.
Kenneth Brown is offline   Reply With Quote
Old 02-06-2004, 10:24 AM   #10
PureChevy
PureChevy's Avatar
thanks for the input yall.
Looks like i will go with the HEI first.
