Windshield trim difference
Can someone tell me the difference between the stainless windshield trim on a 67-70, and a 71-72? Replacement sets are sold in this manner, but I don't know why. Is it the gasket that is different, so the trim needs to be different, or is the trim just thinner / thicker, etc? Looking at a couple sets, but don't know what years they are from. Thanks all....
-adam |
Resident Curmudgeon
![]() Join Date: Dec 1999
Adam, I don't have a side-by-side pic for you but the 71/72 trim sets deeper into the gasket, so both the trim and gasket have to match. As long as you have a match, you can put earlier trim on a leter truck and vice-versa.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Thanks Jeff....that's what I figured, but just wanted a second opinion. Common sense tells you that if the windshield itself did not change, and the cab around the windshield did not change, that it must be the gasket / trim combo that changed.
I only need the 2 upper corner pieces that connect the top and side / bottom pieces, but nobody seems to have just those 2 pieces they want to get rid of. Thanks again.... -adam |
