Out of the carpool lane.
Should a radiator overflow tank be vented to atmosphere or should it be sealed up?
Seems so simple, but started thinking about it and now I'm not so sure if I understand how the system is supposed to work.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Wiseass secured himself a BAN
It is supposed to be vented. When the radiator heats up the water expands past the limits of what the radiator can hold. So the radiator cap is pressure sensitive (usually 15 pounds) and allows the expanded water to flow in to the overflow tank when the radiator pressure reaches 15lbs or over. When the engine cools down the contraction of the once hot water is slowly sucked back in to the radiator. Hope this helps.
New KISS Band
I dont have an overflow tank on my truck I just use a 18 lb cap it dosent allow any fluid to come out
67 chevy 350 HP 4bolt main turbo 350 3.73 gears |
Scotts67,
That doesn't seem like it can be good for the truck. If the water gets hot and expands it has nowhere to go, except through a gasket, or hose.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
its all about the +6 inches
An 18 pound cap is not a good idea at all. If all the gaskets are good and hoses are good, it can literally blow out the radiator or heater core. I have seena few come through our shop like this.
Try spinnin 4 rear tars
On the overflow tank, make sure the inlet is submerged in the coolent, otherwise the coolent wont get sucked back in to the radiator. If you use tank with a hose going in the top, the hose would have to go to the bottom, or if you look on other vehicles, the hose is connected a the bottom.
Just makin sure... ![]()
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
How critical is the level of the overflow tank
I am ready to install an overflow tank also, how critical is the overall vertical level of the tank relative to the radiator cap? In my installation, the top of the overflow tank is ~ 2" below the level of the radiator cap. Hose from the radiator filler neck goes to the bottom of the overflow tank, the top of the overflow tank is vented to atmosphere via another hose that travels downward and exits below fender level so if it ever does overflow through the top it will not collect in the fender and radiaotr support , etc. Sound OK? Thanks
#8 | |
New KISS Band
I would check it out!! You don't want to blow a head gasket or a hose over something as silly as a radiator cap.
New KISS Band
Thanks for the info I will be sure to change that
Can't kick the addiction!
This is the over flow bottle that I put together and getting ready to install but I'm not sure what radiator cap I should use. Any suggestion?
Z, Get a 15 pound cap for a 77 chevy pick up. A 77 should have the puke tank stock. Personally, I always get the Stant cap with the pressure relief lever.
I used the same bottle for a recovery tank, but didn't put a fitting on the bottom like that, I just made sure the hose on the inside went to the bottom of the bottle. |
#13 |
CCRider
The cap is what makes it work...if you have a cap that is not designed for a recovery tank, it will never "suck" the coolant out of the tank and back into the radiator. What's the differance? Just turn the cap over and look at it. A cap not designed for a recovery tank will just have rubber on the plunger under the spring. One designed for a tank will have a second rubber gasket along the top. This is what seals it and allows it to create a vacuum to suck the coolant back. A cap for a recovery system will work fine without the tank but not vice-virsa.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
#14 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: How critical is the level of the overflow tank
#15 |
Thanks Stocker, I figured it would be OK! I've been running the setup for a few days and it seems to be working well. No more puking coolant all over my gargage floor...
#16 |
MOVE OVER
Now I know why my truck blew off its upper raditor hose yesterday,, and spewed antifreeze all over the block! I just put on a 18lb cap on it.. geeze... the water pump failed and the pressure just blew! I'll post the other part of the story on another post, basically not a fun day yesteday!
No matter where you are..... There you are... Buckaroo Banzi |
#17 |
Or run no bottle at all! It will go down about 1 " the first time and then stay that way. Run a hose down past the rad so she drips on the road!
:p ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
