Old 02-06-2004, 07:09 PM   #1
TIMSPEED
TIMSPEED's Avatar
Would kinked fuel line cause idle problem?
I MAY have figured out my strange rough idle problem. I noticed that the line going from my PUMP to the CARB, is kinked...actually, I kinked it, haha. I tried to give it a 90º bend, by hand...never really thought that it'd hurt anything, until I read another post on here about kinked fuel line causing bad idle. So, I'm gonna just put a barb fitting on the pump, and run rubber hose up to the carb. Anyone done this?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-06-2004, 07:17 PM   #2
TIMSPEED
TIMSPEED's Avatar
Originally posted by Riptide's 78p/u
I ran a rubber hose, and all I can say is be carefull. it will eventually rub thru
Rub thru? What you mean?
See Them Here
Old 02-06-2004, 07:18 PM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I agree with Riptide. get a braided line from pump to carb. I did this and looks much better and alot easier to manuever.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-06-2004, 07:25 PM   #4
TIMSPEED
TIMSPEED's Avatar
if you dont run it carefully it may rub on the water pump, the alt bracket or anywhere
Aww gotcha. Ok, Steel Braided is $15. I'm gonna try rubber first, to SEE if it'll cure my idle problem. If it does, then I'll get the steel braided.
See Them Here
Old 02-06-2004, 07:33 PM   #5
79BIG10
79BIG10's Avatar
Summit has a kit to run from your pump to the carb that you have. Just make sure to run a filter in it as well.
Old 02-06-2004, 08:40 PM   #6
TIMSPEED
TIMSPEED's Avatar
yeah, for $40. I already have the fittings and filter, just need the hose.
See Them Here
Old 02-06-2004, 10:35 PM   #7
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
a kinked fuel line wouldnt cause idle problems before it caused high load problems...
mike
mike reeh is offline   Reply With Quote
Old 02-06-2004, 10:50 PM   #8
1FaastC10
1FaastC10's Avatar
Tim, have you ever run out of gas? the truck dies because of lack of fuel. when you restrict the fuel flow, the same thing happens, but not enough to kill the truck.
1FaastC10 is offline   Reply With Quote
Old 02-06-2004, 11:33 PM   #9
Blue Beard
Blue Beard's Avatar
I just looked at a truck that had the same issue.
The guy didn't even notice it.
Was kinked around a bracket.......almost enough to completely cut off the duel supply....and it was a metal line.
He couldn't figure out why it was hard to start and ran rough....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-06-2004, 11:39 PM   #10
TIMSPEED
TIMSPEED's Avatar
Fixed the kink..no change. STILL runs rich and like crap. I'm gonna swap back the primary jets (got a #66 in there now, gonna go back to stock #64) and HOPEFULLY that'll do the trick.
See Them Here
Old 02-06-2004, 11:56 PM   #11
mike reeh
mike reeh's Avatar
what seems to be the problem with your carb anyways? And how are you so sure that its the carb thats causing problems?
I saw you say something about rough idle.. primary jets have nothing to do with the idling of your truck.. What kind of carb? quadrajet I assume.. You check for leaky throttle shafts? leaky well plugs? How long since the carb's been gone thru? etc etc
mike
Old 02-07-2004, 01:54 AM   #12
TIMSPEED
TIMSPEED's Avatar
Yes, the truck has a "twitch" at idle, but it's not all the time. Also, the carb is a Holley 4160. I recently cleaned it and put new fuel bowl gaskets. I bought it 5 years ago though...Amazingly, Holley doesn't even PRODUCE the carb anymore (Model #80460) It was SUPPOSED to be the CARB legal version 4bbl for 74-78 Chevy Trucks originally equipped with a 4bbl carb.
See Them Here
Old 02-07-2004, 02:40 AM   #13
BaggedC10
Under construction!
BaggedC10's Avatar
TIMSPEED and his never ending truck problems.....
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 02-07-2004, 07:05 AM   #14
79BIG10
79BIG10's Avatar
Just an idea but check your fuel float levels. With that new gasket you installed the floats may have been moved up or down to where they're not set right.
