Where do you buy...
A float for the gas tank sending unit? I need one for my blazer tank in my truck. It seems I have a pinhole and no-one seems to know where to get one. Called all the major parts stores including chevy. Everyone says I have to buy the whole assembly. Sounds like BS to me. If anyone knows where to get one, or has one they don't need please let me know! Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
i have heard of people making one out of cork or material like that that will float
70 longbed 496/th400/Ford 9" |
gmc pauls has them on his site for like 8 bucks
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
![]() Join Date: Feb 2001
He's running a blazer thank I believe. 175 bucks through GM. I may have a old sending unit. Will look later.
its all about the +6 inches
If you can drain the float you have now, you can seal it up and reuse it.
DON"T put a torch to it!! Use one of those liquid metal fillers.
scott
Silence is golden, duct tape is silver. - Scott |
Thanks for the replies, Mudder67,if you get a chance to look, I would appreciate it. I only need the float. I tried to find the hole in the float, but I can't get any air bubbles when I submerse it in water. I thought bout drilling a small hole, drainig it then using JB weld, but I'm concerned it might make the float heavier, and I don't know how well jb weld holds up to being submerged in gasoline.
I have new ones available for $8
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
#9 | |
Ya'll hear that? We's usin' codenames. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I'd say for 8 buck's you can't go wrong with that price....Just get a new one!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Shawn
Is this the float you have?
FRENCHBLUE72, problem with the new ones, is they are known for leaking and filling up with fuel.
Granted, I have not done it, but I know I have heard quite a few ppl say it over the years on here. |
#13 |
We have complete new sending units for 45.00 or brass floats for 5.00.
Rest in Peace Ed. Thanks for all the good times. |
#14 |
Mudder67,
No, unfortunately mine is the brass float. But thanks for checking on it for me. Thanks for all of the replies. I called The truck shop and this is what they told me, it's kinda odd: I can send the whole sending unit back, and they will replace it (which means I can't drive the truck) I can buy a new float (also 5.00), but they have a minimum phone order of 25.00. And they charge 8.00 shipping. They can't send me a new float if I fax them a copy of my reciept for the tank and sending unit. I liked them in the past, but they are seeming a little non user friendly nowadays. Mothertruckers I am going to PM you with some questions.
