Old 02-07-2004, 11:01 PM   #1
TIMSPEED
TIMSPEED's Avatar
[Pics]Bagged 83 C10 at a local show today..
The owner was nowhere to be found..but I have to say, it LOOKED like crap. I THOUGHT he did it up nice (4 link) but it's Cantilever isn't it? The bed is stupid too, it's a lifted bedfloor...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-07-2004, 11:03 PM   #2
TIMSPEED
TIMSPEED's Avatar
These are 20's with 35 series rubber
See Them Here
Old 02-07-2004, 11:03 PM   #3
TIMSPEED
TIMSPEED's Avatar
Stock exhaust.
See Them Here
Old 02-07-2004, 11:04 PM   #4
TIMSPEED
TIMSPEED's Avatar
Camera on the ground in front of the truck...if you'll notice, he's actually LAYING on the part of his tranny crossmember that dips down under the catalytic converter.
See Them Here
Old 02-07-2004, 11:05 PM   #5
Prerunner1982
Prerunner1982's Avatar
lifted bed floor=body drop... cab floor was probably raised as well...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-07-2004, 11:06 PM   #6
TIMSPEED
TIMSPEED's Avatar
See Them Here
Old 02-07-2004, 11:07 PM   #7
TIMSPEED
TIMSPEED's Avatar
I don't even know what to say about this...
See Them Here
Old 02-07-2004, 11:08 PM   #8
TIMSPEED
TIMSPEED's Avatar
That's what my friend thought..cab floor was stock...like I said, this truck was ghey.
See Them Here
Old 02-07-2004, 11:11 PM   #9
low 84
low 84's Avatar
looks like 2 link rear and looks like the front of the truck was Z'd. thats why hes on the tranny x member and not the lca's
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-07-2004, 11:15 PM   #10
TIMSPEED
TIMSPEED's Avatar
See Them Here
Old 02-07-2004, 11:18 PM   #11
Prerunner1982
cant imagine they would body drop the bed and not the cab.. the read for doing that is to lower the truck with out modifying the suspension.... the body lines still line up.. sorta..body seems high in the middle.
Jon
Oklahoma Roll Call
Old 02-07-2004, 11:21 PM   #12
TIMSPEED
TIMSPEED's Avatar
I have heard of people doing a stock floor pan bodydrop...but this is stupid. I could bag my truck and lay rocker without doing any major mods, and it'd be nice clean and easy.
See Them Here
Old 02-07-2004, 11:22 PM   #13
Prerunner1982
ok with is Zed that might explain the stock cab floor...
Jon
Oklahoma Roll Call
Old 02-07-2004, 11:48 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
You are correct. Look at the top pic in front of that wonderful valve and plumbing nightmare. You can see where the frame was cut, raised, and gusseted. I wonder if his speedometer works
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-07-2004, 11:59 PM   #15
TIMSPEED
TIMSPEED's Avatar
Anyone notice his dump valves are galanized plumbing pipes? hahaha!
See Them Here
Old 02-08-2004, 12:04 AM   #16
r0lf-
Hotwheels?
r0lf-'s Avatar
Not to be rude or anything...
BUT. You posted pics of this truck you saw at a show just to talk smack about it? Whats wrong with stock exhaust? Theres nothing wrong with raising the bedfloor to not need to cut the bed. Some people just like it that way, its cleaner to them.
Yes the fuel cell is kinda dinky, but whatever. Its not THAT bad of a truck and it looks like a work in progress.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 02-08-2004, 12:10 AM   #17
low 84
low 84's Avatar
tim look in your 3rd pic. see those welds on the frame? what he did was cut the front subframe off and move it up a few inches and weld everything back together. the tips of the frame rails then have to be cut off then lowered back on to keep the bumper nd core support in the right spot.
'05 1500 Crew Cab
RIP
Old 02-08-2004, 12:38 AM   #18
TIMSPEED
TIMSPEED's Avatar
Originally posted by r0lf-
You posted pics of this truck you saw at a show just to talk smack about it? Whats wrong with stock exhaust? Theres nothing wrong with raising the bedfloor to not need to cut the bed. Some people just like it that way, its cleaner to them. Yes the fuel cell is kinda dinky, but whatever. Its not THAT bad of a truck and it looks like a work in progress.
I'm not bagging on it. Stock exhaust is ok..the bedfloor IS cut..you can see where he first just cut the center out of it, then didn't like that, and welded it back up and lifted it all up. And the fake bedfloor didn't go to the end of the bed, there was a 3" gap. Also, it looked like a body lift under the truck...which is what I THINK they used to raise the bedfloor...
See Them Here
Old 02-08-2004, 01:22 AM   #19
phantom dually
Project92 SWB stepside
phantom dually's Avatar
At first glance it looks like a good piece of work in progress. That truck could be cleaned up with little effort and be a great SAFE cruiser!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-08-2004, 12:32 PM   #20
Low87on20s
Live from Atlanta
Low87on20s's Avatar
I like the stance of the truck in the first pic. I also like the seats with the shoulder harness in them. Did you get any pics of the interior?
Paul
Low87on20s is offline   Reply With Quote
Old 02-08-2004, 01:06 PM   #21
bagged74
its just $$$$$
bagged74's Avatar
If you think this is true, and is so easily done, why is your truck still way up in the air. you will have a hard time laying rocker " without any major mods" why is it that you are talking $hit about this guys truck and picking it apart. Lets see some pics of every little detail of your truck, ya know just so that it's fair.
bagged74 is offline   Reply With Quote
Old 02-08-2004, 01:12 PM   #22
phantom dually
I really doubt that these trucks will lay rocker without any major mods. The crossmember will hit first then you have the tranny member to worry about. After that you have to notch the rear to get any size of rim under the truck. Dont let the pics fool you. The guy actually has alot of time in his truck but IMO he didnt take the time to clean it up as much as I would have. I think that the crossmember mod as well as other mods required are major mods and cost $$$$$
Old 02-08-2004, 01:42 PM   #23
SCOTI
SCOTI's Avatar
It could also be possible that he got it finished minutes before that show/cruise & was just anxious to be part of the group so he zip tied stuff in place just to be able to test everything out.
It may not be up to your high standards but opinions are like.....
Some stink, some don't.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2004, 02:12 PM   #24
Izzy
Trucker.
Izzy's Avatar
Actually no you can't. Even with a sectioned crossmember and bags you're still gonna be about 1-1.5" from laying rocker.
Izzy is offline   Reply With Quote
Old 02-08-2004, 02:15 PM   #25
Izzy
Trucker.
Izzy's Avatar
That's what a lot people are using. I personally wouldn't but it's all up to what you can afford. If those things can handle plumbing and all the other crap they are rated at they're fine for street use as long as the pressure is right.
