Old 02-08-2004, 12:53 PM   #1
jcueckert13
jcueckert13's Avatar
summit headers??
has anyone used these headers? i am doing a budget build up on the 350 my 70 gmc c-10 and saw these in summit. they say for off-road and racing use only but becaues i dont need the emissions stuff cant i use these for street use? thank you in advance fro any help
http://store.summitracing.com/partde...rt=SUM%2DG9006
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 02-08-2004, 01:13 PM   #2
ChevyDude
Just bought them for my 71' SWB daily driver. They look good and cost around $180.00 for the Summit ceramic coated ones. My 72' K-10 has Flow Tech ceramic headers running into Flowmasters and it had no problem passsing emisions.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 02-08-2004, 01:50 PM   #3
jcueckert13
chevydude what trans dose your truck have? i would like to know weather they fit on a truck with the 4 speed manual transwith out modifying the clutch linkage?
1976 Dodge Dart
1963 Dodge Dart
Old 02-08-2004, 03:20 PM   #4
dregs454
Killin' Time
dregs454's Avatar
I have fairly cheap dynomax blackjack headers, and they fit around the 4 speed clutch linkage no problem
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 02-08-2004, 04:35 PM   #5
jcueckert13
thank you guys, now i at least i have some options
1976 Dodge Dart
1963 Dodge Dart
Old 02-08-2004, 05:07 PM   #6
ChevyDude
My 71' 3 on the tree for now. I just got the headers so I don't know if I'll have to modify or not. I will make it work no matter what needs to be done, if anything.
Alex
Old 02-08-2004, 06:27 PM   #7
jcueckert13
thanks again chevydude
1976 Dodge Dart
1963 Dodge Dart
Old 02-08-2004, 06:34 PM   #8
bad 71 chevy
bad 71 chevy's Avatar
i put a set of headers on my 3 speed and i hade to modifi the header to make them fit
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 02-08-2004, 08:38 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
ChevyDude, look closely at those down by the collector and you should see a part number stamped into the header. That's a Dynomax part number. The Summit 180 dollar ceramic headers are reboxed Dynomax units. I put a set onto my old 72 1/2 SWB a couple of years ago. I have pictures of them if you want. No real complaints I guess. The hang a little low under a lowered truck, but nothing too bad.
Old 02-08-2004, 09:03 PM   #10
ChevyDude
I just wanted a cheap set, that's why I got these. Love to see pics Tx Firefighter. I guess hanging low means "Watch it" on the speed bumps eh. My Prowler sits no more than 4" above the pavement and all speed bumps must be taken sideways at 0.1 mph (Crawling), so I don't see these headers being too low. Thanks for the warning though. Will I have to modify to make them work with 3 on the tree?
Alex
Old 02-08-2004, 09:20 PM   #11
bad 71 chevy
i put headman headers on and had to modifi the header to fit
5 speed nv3500
3.73 rear end
Headmen headers
Old 02-08-2004, 09:27 PM   #12
Tx Firefighter
Chevydude, I too wanted a cheap set of ceramic coated headers so I ordered the Summit brand ones. Then, when they came in and I looked at them real close, I saw the part number stamped into each one by the collector. When I looked around on the web, I saw that it was a Dynomax part number for 63-87 Chevy trucks with small block. I was very happy.
Here's a picture I've posted before of the headers under the truck. The truck now belongs to my neighbor. He left the hood off of the truck for over 6 months, so the weather kind of beat the finish up a little, but they still look prety decent. This truck is lowered 4 1/2 inches in the front with 26 inch tall tires, so it's fairly low. You can see the ground clearance in the picture. When I asked him, he said he had barked them into speed bumps twice since he's owned the truck (about 3 years). When I sold the truck to him, they were still in the box, and he installed them the next weekend on the truck.
I don't know about the clutch linkage, this truck is an auto.
Old 02-08-2004, 09:55 PM   #13
ChevyDude
That is low! Boy you weren't kidin'. Thanks again.
Alex
Old 02-09-2004, 12:35 AM   #14
jcueckert13
well its nice to know the summit headers are the same thing as the dynomax. thankfully ground clearance is not a problem concitering that my truck will be on 31 inch tires and at stock height
1976 Dodge Dart
1963 Dodge Dart
