Guage Question
I was looking at a picture the other day and I was wondering. Could I change all those guages to an after market set? Something like AutoMeter or something?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
its all about the +6 inches
yup. I did the acc guages only...I think mudder did his whole dash.
FUEL CELL GURU
Yep...
I had an original dash before I started building this one. Pretty easy project.
![]() Join Date: Feb 2001
Here's mine
5inch
3 3/8 2 5/8 |
Young Gun wth Fast Inline
fcg i must ask what are you going to do with all those gauges?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
FUEL CELL GURU
Here we go...
Of course, 5" tach, 5" speedo; 2 3/8" volt, fuel level, water temp, oil pressure, vacuum, and trans temp; 2 1/16" air pressure (x5)- 1 for each air bag and 1 for the tank. It may very well look like a pilot's cockpit when it is done. It ought to look pretty good.
Try spinnin 4 rear tars
Geez FCG, that's a lot of information (not to mention a lot of $$$ in gauges
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
![]() Join Date: Aug 2001
![]() HERES A SET I'M BUILDING FOR MY LATEST VICTUM.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
FUEL CELL GURU
Well..
it won't be too bad $$$-wise. I bought 7 new gauges for $100 from a buddy. I kept the ones I need and sold the others on ebay. I ended up getting 4 gauges I needed and $80 for the ones I didn't need.
How are you guys wiring these? Are you keeping the plug harness that plugs into the circuit panel?
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
FUEL CELL GURU
Well...
I.....
I used the wires for the turn signals, and dimmer switch from that harness.
#13 |
Painless
I bought the Painless universal dash wiring harness so I can unplug it for easy removal of my Boese Engineering billet dash.
scott
Silence is golden, duct tape is silver. - Scott |
#14 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
You can also go this route very beautiful piece of work...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#15 |
Just remember the $189 doesn't include gages! LOL Scott
#16 |
Why is that water temp gauge black, and the others are white in that last post
![]() Also... Would getting another glove box door and installing gauges in it fit?! Just grab a nice hefty hole saw set, and cut some holes in it. Mount them up, do something fancy for the steering column, and put a couple of holes in it to mount it to the dash...
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB Last edited by SWEET7T; 02-10-2004 at 05:22 PM. |
#17 | |
Thats exactly what I want and need except with all white gauges...I will probably need one or two more gauges than whats there...I will have to make a list... Yup vacuum and trans temp...
