Old 02-08-2004, 01:58 PM   #1
roadking
starter heat shields
new crate motor in, runs great! put the dynamax headers on (not ceramic) and already having starter problems getting hot and not wanting to start until cool down, just wondering if anyone has put a heat shield on thier starter and sylenoid and solved this problem. summit sells one for 25.00 but i hate to spend cash if its not going to help. any advice is appreciated.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 02-08-2004, 02:04 PM   #2
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Here's a fun way to see if a heat shield will help...
1. Drink a beer or two and cut the empty can to fit over the solenoid.
2. Test
If a shield doesn't help, the best fix is to install a Ford solenoid on your firewall or fender. Another advantage is that you won't have to worry about getting it wet.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 02-08-2004, 02:13 PM   #3
roadking
should i take that as not much luck with heat shields? this is my first vehicle with headers, ive always kinda been one of those stock guy.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 02-08-2004, 02:33 PM   #4
Piper71c10
Unending Project
Piper71c10's Avatar
How do you wire it together with the ford starter solonoid ?
Piper
Piper71c10 is offline   Reply With Quote
Old 02-08-2004, 02:59 PM   #5
kaycee
kaycee's Avatar
Good to the last drop
I used a empty coffe can and cut it in half and used the starter bolts to hold it on.Has worked good for the last coupla yrs.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-08-2004, 03:05 PM   #6
tom hand
CCRider
tom hand's Avatar
I have a motorhome with a 454 ....no headers but the solenoid was geting so hot it was deteriating the bakelite on the front of the solenoid. Cambells soup can, fiberglass insulation, and a large hose clamp...no more problems. Paint it black and you would never know the differance
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-08-2004, 05:01 PM   #7
gabet40
spectre makes a nice shield too that i have layin around. but its probly similar to the summit one and cost about the same
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 02-08-2004, 06:57 PM   #8
barn9
Half a bubble off!
barn9's Avatar
Here is a link to a remote solenoid kit that comes complete and makes for a nice, quality, and clean conversion. You can patch one together cheaper, but this guy has done his homework, and everything except a battery cable is in the kit. This guy has some other useful electrical items also.
Remote solenoid ST-1
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-08-2004, 11:22 PM   #9
Blue Beard
Blue Beard's Avatar
Wouldn't be that hard to fab something clean and simple to work out the problem.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-09-2004, 12:48 AM   #10
ScottH
ScottH's Avatar
BTW, I have the same problem on my truck. Just waiting for it to get warmer so I can drop the starter. I did look around a while back and found JC Whitney carried one that looked pretty good, but can't remember the cost.
Best of luck with it.
Scott
ScottH is offline   Reply With Quote
Old 02-09-2004, 06:08 AM   #11
Javy
Javy's Avatar
barn9
nice solenoids
Javy is offline   Reply With Quote
Old 02-09-2004, 06:14 AM   #12
Javy
Javy's Avatar
roadking
Not to be a dick but if you shelled out the bucks for a crate(or new motor).whats 25 more bucks for a shield and avoid a Ford part in your chevy?
Just my 3 cents.
Old 02-09-2004, 06:22 AM   #13
Javy
Javy's Avatar
For about $120 bucks you can buy one of those high torque starters.At SO CAL swap meets you can buy them for $80
Old 02-09-2004, 11:08 AM   #14
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
I put one on mine, and it seems to help. I had more problems with crappy starters than 'heat soak' but since I had to change starters again anyway I put one on. I picked it up for $8.00 new through a mechanic friend.
It's like this one at Summit
...and it looks like this:
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 02-09-2004, 12:24 PM   #15
67chevemall
67chevemall's Avatar
MINI high torque is the only way to go!
I think they are cheaper if you can find the GM stock ones at the wreckers or new even. I forget the year but they are on a newer GM pick up 2500.
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-09-2004, 03:29 PM   #16
lewi
lewi's Avatar
I'm with 70chevylongbed, A couple years ago I had this same trouble after installing headers (they are ceramic coated). Replaced the starter and installed a shield much like the picture and have had no problems since.
Additional note: I am in an area that gets pretty hot in the summers so I don't know if the ceramic coating is enough in other areas but it wasn't here.
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 02-10-2004, 05:37 AM   #17
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had the mr gasket starter shield on the 454 in my last '67 K/10 Sub, and it worked good. I tried to cannibalize it and put it on my next truck, a '71 Jimmy K/5 w/350 and heddman hedders. It wouldn't fit, hedders too close. So I got an aluminized fabric heat shield to go there now, but I hav'nt put it on yet.
Old 02-10-2004, 10:03 AM   #18
rodnok1
rodnok1's Avatar
Crappy wires and cheap starters always get ya. By a top notch starter(mini or otherwise) and run new wires to your starter, I generally oversize the wires. Most of the time the wires leading down are bad from all the heat. On most trucks you really shouldn't need a heat shield. If you do put somthing on I woulkd get something that insulates and reflects the heat, like a starter wrap.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-10-2004, 12:52 PM   #19
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I use one very similar to the one 70ChevyLongbed posted a picture of. My headers don't kill my starters... 10.5 to 1 compression makes'em last about 6 months... I am going to pony up the bucks after this one dies and buy a mini starter... it shouldn't be too much longer judging from the sounds it was emanating this weekend...
Suicide-D is offline   Reply With Quote
Old 02-10-2004, 01:03 PM   #20
Tom Felso Jr
Thumbs up Heat shield
Corvettes came thru with stock. If you find a guy into older corvettes he should have one laying around. I used all mine.$25.00 is not a bad price though. Beats changing the starter...
Tom
Tom Felso Jr is offline   Reply With Quote
Old 02-10-2004, 04:50 PM   #21
Hooter
My other Love
Hooter's Avatar
I installed one of those MR Gasket heat shields, worked pretty well but after long trips I would still find that I would have problems, so then a put an asbestos mit (the kind they use in metal forging etc..) and havent had a problem since
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-10-2004, 07:53 PM   #22
A.P.
Black 72 Chevy
A.P.'s Avatar
I've installed this heat shield on my starter solenoid, I don't know if it will work but will see as soon as I install my engine.
A.P. is offline   Reply With Quote
Old 02-10-2004, 10:03 PM   #23
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I run the summit heat shield and it seem's to work pretty damn good but my next upgrade is a mini starter..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-10-2004, 10:46 PM   #24
MrGoodpliers
MrGoodpliers's Avatar
I had a '34 5 window with a vette 327, block huggers and pipes went right under the starter. I could only get it out one way-- spinning and cajoling to get the solenoid on the correct side, then up between the firewall and valvecover. I cooked about 5 starters before I broke down and bought a Tilton. End of problem. Sold the '34, now my trucks all have factory manifolds But if I were to put headers on something again, I would do the mini starter thing at the same time...
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
