wiper washer help please
just put in new dash bezel, and wanted to do the washer pump at the same time, all back together, pumps great, just wont shut off! Can someone please help with this? could it be the wiper switch? just stays on and pumps while wipers are on, same on high too, just pumps faster. thanks
beater 65 gmc at the moment |
Florida Key's Member
pumping pumping
my washer pump did the same and what i had to do was remove the washer and wiper motor and clean it all up
Craig Wood 1972 SWB Chevy Cheyenne 4X4 Restored stock except 454 (481 cu. in. now) most options Available pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528 Come to florida and visit www.Paradisewatersports.com |
pumps stuck......
just reading your post is making me want to pee ![]() you'al get'er ![]() |
Interesting..I'm having the same problem. Ended up dumping the reservoir just because I didn't have time to pull the thing apart(and every weekend for the last several has brought rain!).
My guess is the lever actuator between the wiper motor and the washer pump has a tendancy to stick. Hopefully disassemble and clean up will fix it.
1968 C-20 Custom Camper package Chevy Red (iow: orange!) |
Something that I did to make it a little better. I bought a reservor and pump for a 87 chevy truck. The plastic reservor has a molded place in the back of it for the pump to snap into, the suction of the pump is mounted inside the reservor at the bottom. the pump has two wire just like our orangal pump under the dash, I ran two new wires out to the pump from the plug in connector that runs the original pump, and it all works. I did this so I don't have to pull the dash out every time the pump decided to quit. Also the new reservor hold more fluid. I just did this last week, up graded every thing for the windshield wipers. New motor, delay wiper switch, and new reservor with new pump. Works great. By the way, I had my cowling off in the process of doing this, cause I put in new squirters, the kind that sprays out two streams of water on each side. While I had the cowling off, I put a screen across the inside of the cowling to keep leaves and debrie from getting into my side vents.
72 LWB chevy truck. Pasadena, Texas |
Saving 1 truck at a time!
Great idea for an upgrade!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
