Old 02-08-2004, 09:39 PM   #1
71Rat
ran out of money
71Rat's Avatar
an engine ????
Ok well here is my question how do you replace cam bearings? like how do you get the old ones out and the new ones in?????
Thanks for your help
PS i need to get this truck running again so i can
Thanks RAT
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 02-08-2004, 09:45 PM   #2
rage'nrat638
rage'nrat638's Avatar
cam bearing install tool.....
got the engine out?
rage'nrat638 is offline   Reply With Quote
Old 02-08-2004, 09:47 PM   #3
john
member #16
john's Avatar
Engine shops use a driver to remove and install cam bearings. Easiest way is to have a shop do it. Tool would cost too much unless you do alot of them. John
john is offline   Reply With Quote
Old 02-08-2004, 10:08 PM   #4
71Rat
ran out of money
71Rat's Avatar
how much is a cam bearing tool? and yes the engine is out and all apart... ready to go to the machine shop once i get home from school for a weekend. i can't wait, but i need new bearings.... i want this engine to last a lot longer
Thanks again everyone
Rat
Old 02-08-2004, 10:34 PM   #5
neonlarry
neonlarry's Avatar
If you are going to take it to the machine shop anyway its easier and cheaper to have them install the cam bearings while its there.
But if you insist on doing it yourself the tool runs around $200+ check here .
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-08-2004, 11:11 PM   #6
bigjimzlll
bigjimzlll's Avatar
you can get bearings R&R and supplied for around 40 bucks at the machine shop..no reason to do it your self
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-08-2004, 11:15 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you've never installed cam bearings, have the machine shop do it.They will probably be tanking the block and doing so will degrade the cam bearings.Alignment on certaintypes of cam bearings is also critical.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-08-2004, 11:49 PM   #8
71Rat
ran out of money
71Rat's Avatar
I am going to allow the machine shop to put the new ones in. the thing is i am going to school to become a mechanic and havent got to my engine rebuild class yet... so i figured in the long run i might end up buying a tool. thanks for everyones help.
Rat
