Old 02-08-2004, 11:05 PM   #1
Couchsachraga
'74 4x4 dump axel questions...
Greetings...
I just picked up a '74 dump that was billed as a 1 ton...definitely 3/4 front end (not "bud" style wheels as we call them all around here, and 8 lugs...). Rear is dually.
Anyway, does anyone know what I've got under here, what the capacities are, and what else they were used in? I'm trying to figure how much I can put in the dump (does have the overload springs, and I'm pretty sure it's all factory...).
I'm assuming the front is a Dana 44...., and am mostly wondering about the rear end (same as 1 ton 2wd, or is it really a 3/4 ton axel as well? What other vehicles might it have been used in? (in case I come across a parts truck ).
Thank you in advance!
Couchsachraga
Couchsachraga is offline   Reply With Quote
Old 02-09-2004, 12:16 AM   #2
Destructo
Should be a 14 bolt Full-Floating axles. And do you think somebody converted from 1-ton front end to 3/4 ton? Are you sure it doesn't have a D60 in the front? D60s and D44's look pretty similar on the diff cover. But D44 has ball-joints and the D60 has king-pins.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 02-09-2004, 04:08 AM   #3
1969 GMC
1969 GMC's Avatar
also, d60 has only one ubolt on the passenger side of the diff, and then 2 studs where the other ubolt should go. and there will be a slight bump above the fill plug on the diff cover that the d44 doesn't have.
the rear axle is most likely a 14 bolt, but could be a dana 70. count the diff cover bolts. 14=14 bolt, 10=dana 70.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-09-2004, 08:04 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The dana 60 did not appear until 77 for the one tons. To add to Adam's post the dana 70 and 14 bolt are for all practical purposes identical in strength.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-09-2004, 09:25 PM   #5
Couchsachraga
Well, I haven't crawled down in the snow to count the bolts yet, but I DID check out the plate inside the door:
Front Axel Capacity-3500lbs
Rear Axle Capacity -3950lbs (or may have been 3850)
Thanks for all your help! I picked it up and drove it to a shop tonight (needs new rear brake line, possibly wheel cylindars with my luck).
Couchsachraga
Old 02-09-2004, 09:32 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That 3500 is right in there for a dana 44.
Old 02-10-2004, 06:47 PM   #7
Couchsachraga
Ok, more info...any comments regarding true capacity of the truck would be appreciated!
GVWR 6800 (inside door panel)
Vehicle weight 4200 or so (I'm assuming it's there for a 1 ton?
Rear axle is 14 bolt, as you all thought. Nice 8.75 x 16.5 's all around.
Does not have overload springs on rear, and it does not look like a factory bed (on the factory dumps I've seen the hinges were integral to the chassis-here it's placed on top of the chassis and shimmed with wood. Looks like a job well done, or a professional job around here...)
Any other location to find out more info on truck? All the identifying markings were removed when it was repainted and not replaced....
Thanks again for all your help! Once I get a rocker and fender replaced I'll try and post an image of this beast!
Couchsachraga
Old 02-11-2004, 06:44 PM   #8
Blazer1970
Blazer1970's Avatar
6800 GVWR is a 3/4 ton, not a 1 ton.
Blazer1970 is offline   Reply With Quote
Old 02-11-2004, 08:16 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yeah my 70 has a GVWR of 7000. (7200 max I believe)
