what is a carrier?
what is a carrier in a rear end. i know my 12 bolt has a 3 series carrier because it has 3.07 open gears so if i want to switch to 3.73 i need aftermarket ones to fit a 3 series carrier. but what actauly is the carrier? is it part of the spider assembly in the center of the ring gear or what??? basically reason i want to know is if i take out the spider assembly crap and go to a mini spool do i still have a 3 series carrier and need 3 series 3.73 r&p?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
The carrier is the large rotating assembly in the rear end. The ring gear bolts to it, and the spider gears, cross shaft, and side gears are all "carried" within the carrier. Removing the spiders and using a mini_spool, leaves you with the came carrier.
Mike |
#3 | |
Re: what is a carrier?
thanks thats what i needed to know
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
A mini spool replaces the spider gear assembly. A spool replaces the carrier. I personally wouldn't recommend either on a strickly street driven vehicle.
In addition, mini spools are typically not recommended for high horsepower applications. Edit: Plus, who makes a mini spool for a truck application?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 02-09-2004 at 02:24 AM. |
i'm not sure i'm going with one yet. just considering different things now. i was told in another post that a car mini spool will fit a truck and in jegs auburn list one for 12 bolt car/truck same pn
BAD BOW-Silverado XST
lol
Good One!!
