Old 02-09-2004, 01:26 PM   #1
zyggy72
Can't kick the addiction!
Questions about 307
The 71 chevy 1/2-ton truck I brought home this past weekend has a 307 in it that runs good and doesn't smoke or anything. I don't plan on building the motor but I want to know if the 307 is good for an everyday driver/work truck. Were there any problems with them? What were the hp & torque ratings on the motor? Any other information about those motors would help. Any one with past experiences with them?
zyggy72 is offline   Reply With Quote
Old 02-09-2004, 01:44 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
For what you describe the 307 is an adequate engine. It's not the first choice for a small block build up though. It's got a 2bbl carb which I've always thought used more gas than the same engine with a 4bbl with small primaries (until you put your foot into it).
The good news is that all accessory brackets, intake and exhaust manifolds are the same as the 350, so these parts are easy to come by and cheap. So you can add a 4bbl and headers if you wish.
I don't have the factory specs on this for you.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-09-2004, 01:47 PM   #3
JimKshortstep4x4
Talking
We run a 307 in two of our daily drivers and the 307's are a very good serviceable engine. Gas mileage is good, power is OK but not like a 350. If you need to tow, it would be better to have a 350. They last a long time. I don't believe that I would ever rebuild one as they are more costly to build than a 350.
Overall, I think they work real well in these trucks, especially if you are doing long trips.
Jim
Old 02-09-2004, 02:12 PM   #4
1972C10
1972C10's Avatar
283 bore with a 327 stroke.. Only good thing about them is that they use a large journal 3.25 stroke crank so you can build up a 350 block with 327 pistons good large journal rods and that 307 crank.
1972C10 is offline   Reply With Quote
Old 02-09-2004, 02:32 PM   #5
zyggy72
Wow! This is a big help so far. Thank you for the information that you've given.
Old 02-09-2004, 02:40 PM   #6
Zumo
Hot Rods For Life
Zumo's Avatar
Not a good motor to tow or haul heavy loads. I pushed my 307 to the limit and broke a rod. I am in the process of installing a rebuilt 350 now.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 02-09-2004, 02:55 PM   #7
zyggy72
I don't plan on doing any towing with this truck and it will only see an occasional heavy load besides the tool box I will have in it. The truck is only a 1/2-ton swb fleetside, just a light duty work truck/daily driver.
Old 02-09-2004, 03:04 PM   #8
JimKshortstep4x4
Talking
We run q-jets on both of the 307's. The mileage went up some with the q-jet under normal driving conditions.
Jim
Old 02-09-2004, 03:12 PM   #9
zyggy72
From the sounds of it, I'll change the intake to a 4-barrel intake and put the q-jet that I have on top of it. I also have a set of headers and a custom dual exhaust system that I will install too.
Come to think of it, I will clean one of the hei units that I have and add that to the 307 also. Anyhing else?
Old 02-09-2004, 06:01 PM   #10
Z28Owner
Z28Owner's Avatar
I got a 307 I drive everyday. I have installed a HEI, 600cfm carb and performer intake, clutch fan. Gonna get the headers on there in a few weeks. I got a th350 with 4:11 gears, get anywhere from 12-15 mpg longs as I keep it aroun 50-55 and dont open the four barrell. It has no problem pulling itself around, can keep up with traffic easily, but put any weight in it and it is very noticable. All in all a good driver engine.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 02-09-2004, 06:09 PM   #11
MrGoodpliers
MrGoodpliers's Avatar
Hey 1972C10...
I have thought about upgrading my 307 to a 350 using a different block and heads. Mine is a '69, do you think it has a cast or forged crank?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-09-2004, 09:31 PM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
How do you tell if it is a 307 or 350 besides running the numbers? What is a good website to run the numbers on?
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 02-09-2004, 09:32 PM   #13
FirstGen
Just Don't Stop!
FirstGen's Avatar
Don't think they used forged cranks on really any factory motors back then except for some of the rare HO motors? I'd put money on it that's its a cast crank...
TT LSA/6L90e/9"
Old 02-10-2004, 12:11 AM   #14
Z28Owner
Z28Owner's Avatar
http://www.mortec.com/castnum.htm
1971 LWB Chevy C-10
350/350 3:42 eaton
Old 02-10-2004, 02:35 AM   #15
Hooter
My other Love
Hooter's Avatar
I had a 307 in my 69, had a steel crank and a 4 barrel, the motor was a dog, it got the same mpg as my 454 does now, but was not even nearly as fast, in fact it was slow, but that was just my experience
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-10-2004, 02:48 AM   #16
FirstGen
Just Don't Stop!
FirstGen's Avatar
I had a 307 in my 69, had a steel crank...
I hope it had a steel crank
All cranks are steel. Most factory cranks are cast though(cheaper). Any steel crank could be cast, 4340 steel (forged), 5130 steel, etc.
TT LSA/6L90e/9"
Old 02-10-2004, 10:12 AM   #17
MrGoodpliers
I had a '72 truck 4 bolt 350-- forged crank, and a no frills '67 327--forged crank. I figure chances are that it is a forged crank in my 2bbl 307. If someone knows for sure, Zyggy and I would like to know... (right, zyggy? hope I'm not stealing your thread)
Old 02-10-2004, 10:27 AM   #18
zyggy72
Thats OK, I would like to know also.
Old 02-10-2004, 12:13 PM   #19
FirstGen
Just Don't Stop!
FirstGen's Avatar
Nice! I'm surprized. Just courious, how did you know it was forged? I've got a 327 with a thrown rod, maybe it has a forged crank too?
TT LSA/6L90e/9"
Old 02-10-2004, 12:15 PM   #20
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
I have a 307 and have some additional info from some past threads.
blazomatic posted:
"I have a 307 in my 71 K5. I also have the series 10 truck owners manual for 71. In it they rate the 307 with: 135 net hp @ 4,000 and 235 net tq @ 2,400."
In December I just finished making the following mods to mine:
Edelbrock Performer Carb 500cfm (#1404, manual choke), Edelbrock Performer intake manifold (#2101), Engine Works Cam (#135280H) with 214/214 @ .050 duration and .443/.443 lift, new lifters, HEI Distributor (new, for stock 1975 350) new plug wires, R46SZ plugs gapped at .045, short water pump, new fan clutch to fit the new water pump, new water pump pulley (two groove), Alan Grove Alternator bracket (#213L - ALT.), new crank pulleys (three groove – and special spacers for the press-on balancer), new detent cable, new Edelbrock Elite "Signature" air cleaner and some chrome stuff.
stepside454 posted:
"I punched your info into my desktop dyno 2000 .I assumed a 112 LSA on the cam & came up with: 213HP @ 4500 RPMs 277 ft. lbs. @ 3500 RPMS Than I added small tube headers: 226 HP @ 5000 RPMs 297 ft. lbs @ 3500 rpms for a low compression 307 with small valve heads, not to bad, good heads like Vortecs would be a huge gain"
I am very happy with the increased power and throttle response, but I'm not going to smoke my tires anytime soon. I started out wanting reliability for my daily driver, and ended up going a little overboard in a few places. It was a good experience.
Jason
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 02-10-2004, 01:11 PM   #21
MrGoodpliers
Answer for Firstgen
The parting lines on a forged crank are wide and flat, while on a cast crank they will be thin and raised slightly. Also, if the crank is out of the block, if you tap a forged crank with a hammer it will ring like a bell-- cast crank, a dull thud.
Old 02-10-2004, 01:28 PM   #22
zyggy72
Cool! That is good to know.
Old 02-10-2004, 03:25 PM   #23
FirstGen
Just Don't Stop!
FirstGen's Avatar
yeah I knew that about the casting lines, don't think I will be trying the hammer trick though
TT LSA/6L90e/9"
