Old 02-09-2004, 08:09 PM   #1
special70gmc
special70gmc's Avatar
Exclamation need help asap engine problems
okay, i made a deal with my autobldy teacher that wile my truck was in his shop (im painting it now) he could drive it in and out of the shop to make room, BUT the f***ing truck never wants to start. it fouls the plugs every two days at least(acdelco r45's) hes getting really aggitated about this whole thing. all i know is the choke IS working correctly,the primary float setting is about an 1/8 inck down from the sight plug and the seccondary float over flows a little out the sight plug. mortec says i have a holley 4160 the # is 80508 and its jetts are (F)72 (R)plate 134-21 6.5
im nt sure how big the accelerater pump is either.
is this carb too bug for my combo? do i need a 650? please help thanks alot -kyle
355cid LT-1
10.3-1 compression
total seal rings
comp xe274-h cam w/comp roller rockers
vette ''492'' castings w/bowl port
2.08/160 manly ss valves
forged + balenced rotating assembly
1 5/8 headers 2 1/2 exaust w/flows +h-pipe
rpm airgap intake
holley 750
regular gm hei
tci street fighter trans w/2400stall
4:10 posi rear
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 02-09-2004, 08:29 PM   #2
tom hand
CCRider
tom hand's Avatar
Looking at this page :
http://www.compcams.com/Technical/Dy...74H-10_001.asp
that cam doesn't have very much vacuum, so at idle your power valve is staying open all the time if you are still using the stock one. Use this page to determine how to get the correct one
http://www.holley.com/HiOctn/TechSer...fo/CI-121.html
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-09-2004, 08:42 PM   #3
special70gmc
it says i have a 6.5'' triggerd power valve so is that really the problem?
1958 belair 2door
Old 02-09-2004, 09:10 PM   #4
cableguy0
very well could be the power valve is stuck wide open because that cam is pretty big go down a size or two and see what happens. if everything else is working properly than thats the likely suspect. im willing to bet your gets are actually too small front and rear
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-09-2004, 09:15 PM   #5
tom hand
CCRider
tom hand's Avatar
Hook up a vacuum gauge and see what it holds in gear. It doesn't say you have a 6.5...it says that is a good all around one. Holley power vales go up to 10.5 I think and the first page says that cam idles at between 11 and 14 inches. I bet the power valve is opening as soon as you drop it in gear...fouling your plugs
Olive Branch MS
Old 02-09-2004, 09:18 PM   #6
rage'nrat638
rage'nrat638's Avatar
THAT IS A LOT OF CARB....
YOU DID CHANGE THE RESISTOR WIRE POWERING THE HEI RIGHT?
HOTTER PLUGS....
GAP SIZE????
rage'nrat638 is offline   Reply With Quote
Old 02-09-2004, 09:28 PM   #7
Short-Fuse 72'
How low can you go
Damn, you must have your body scraping the ground judging by how high your wheels come into the engine compartment.
Ya'll hear that? We's usin' codenames.
Short-Fuse 72' is offline   Reply With Quote
Old 02-09-2004, 10:43 PM   #8
special70gmc
i actually have an hei modified harness so its all been done for me as well as the int regulated alt, i just threw the puugs in i probly could widen the gap some right?
its not that low i really would like bags tho.....................
just remembered that pic was with 31'' tires before i swaped for 26'' ers lol
1958 belair 2door
