yeller
Factory tachs 101...the real deal.
OK folks, with Daves permission, and both his help and Kens, here is a tech article on factory tachs!
http://www.73-87.com/7387garage/inte...achometers.htm I am now on the hunt for different gauge cluster pics with tachs...so if you got em (and if you KNOW what year it is), please post a pic or two and tell me what they are from. ![]() Thanks Dave and Ken, this will be a time saver for sure when people start asking about them.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 02-09-2004 at 11:30 PM. |
You get what you pay for
![]() Join Date: Dec 1999
Looks good, but let me be a critic for a minute.
You need to change the info about all 86 trucks having feedback carbs. Not true. None of our trucks had feedback carbs except for the ones in California. Unless your truck was built for California, the later Q-jets had the dual capacity pump system only. None of our trucks were computer controlled except for California trucks. Mike |
yeller
Thanks Mike
![]() I got that info from Dave, maybe he will chime in and put his .02 in the pot. I have no clue on this, I am strictly going by what I hear from the people who know. ![]() Dave?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
LED King
Let me also add that the 81-87 California truck did NOT ever come with a factory tach dash. California is special - we get all the crap!
Mike -were all 85 & 86 electronic carbs dual capacity pump? I can't tell if mine is or not.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
Yes. I'm not sure on how far back it goes, but I do know 85 and 86 was.
Edit: I seen where you said Electronic carbs. I'm not sure if the computer controlled carbs had the dual capacity pump or not. I'm thinking not. I'm speaking of non computer controlled ones. They came with the dual capacity pump system only. Just one wire coming from the sensor in the thermostat housing to the solenoid in the carb. This I know for a fact. Last edited by swervin ervin; 02-10-2004 at 01:32 AM. |
LED King
I looked in the Rodchester carb. book I have and it says ALL 85-86 chevy trucks came w/ electronic carbs and dual capacity pumps, but I don't trust it. It shows the electronic carb and the solenoid has extra wire coming out of it for the dual capacity pump on it that mine doesn't have. It is weird as everything else is identical.
Is there a better detailed guide on how to install gauges? or is 73-87's the best guide there is?
I wanted an RPM gauge that'd be nice. |
Sorry, don't know where my brain was. Yes, it was only used in 85/86 trucks. It's important to remember, electronic controlled is not the same as only having the dual capacity pump system.
Computer controlled Q-jets have the idle mixture control solenoid too.
Mike 1985 Chevy C-10 |
LED King
And a TPS. I don't think mine is dual capacity, but I would probably have to take it apart to find out. I think this is one of those gray areas that no one can give a definitive answer to. I'm guessing there were 3 different carbs on these trucks then. Non-computer dual-capacity, computer dual capacity, & computer single capacity. Odd.
#10 | |
I'm back with 2nd truck!
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
LED King
Sorry about hijacking the thread
the only ones i saw were clusters not like dash mounted ones.
linkage? 73- 87 garage section. maybe im blind. |
#13 | |
yeller
#14 |
i was thinking bout a single individual gauge thats mounted on top of the dash , not in the actual cluster itself.
#15 |
Oh ok. Those people just mount them anywhere they want to and are very eas to wire in. One ignition power wire, one ground, one lead to the distributor and finally the last wire to your light switch. This is to light the tach up when you turn on your lights.
#16 |
rocket science i dont speak electrcian.
i dont know to even "hook" them up.. lol im mad n00b. |
#17 |
If you buy an aftermekt tach they will come with instructions. Most of your tachs are wired like this
Red- Ignition power (when you turn over the key it gets power) Black- Ground (attach to metal to complete the "circuit") White- This one connects to the conneection to your lights (I used the wire I had for my old radio that had backlit). Green- This wire goes into the engine bay and on the driver side of the distributor. There is a place in the cap for this.
#18 |
k you rock much easier to understand.
btw i was lookin around its like 25 bucks per 2 5/8th guage? that seems kinda pricey no? |
#19 |
bump
#20 | |
yeller
#21 |
the sunpro tacks are usually about $25, they arent the big racing tachs or anything, my sunpro has a 3" face diameter. and new.. many moons ago it was $25..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#22 |
Oh,you can't buy that new
![]() Join Date: Apr 2000
aptsguy & swervin, thanx for that 85-86 input and i have said all along that i am by no means an automotive tech. I would rather be safe than sorry and always have steered people with stock 86's that have stock carbs/ignition & emissions away from factory tachs because of the VSS issue. out of the 5 or 6 of 85's I've had only one had a feedback carb and all the 86's did. the Feedback QJ's have the MCS(mixture control solenoid) sticking out the top of the carb. Does this or does it NOT (I truly don't know) get it's 'feedback' from an ECM that gets info from a VSS like an EFI 87 does?? I do know that when the MCS gets back or bad signals it goes Full rich and although the truck will still run OK it is miserable on fuel mileage & aceleration. I'm NOT a tach god ,just a bit of a guru.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
#23 |
Dave,
I think you are confusing the dual capacity pump solenoid for a MCS. True, it's in the same place as the MCS, but all it does is control fuel flow to the accelerator pump. The sensor in the thermostat housing sends a signal to the solenoid when coolant temps reach around 160-170 degrees. This then energizes the solenoid and the pump valve opens reducing the amount of fuel going to the accelerator pump by 1/2 the volume. This is all this is for. I'm not sure on GM's reason for this in 85/86 but I'm sure it has something to do with emissions. I figure this is the reason it was only in 85/86, right before they went to TBI. I've never seen a computer controlled 85/86 pickup. Only heard about them from the guys in California. There were no computers installed in any of these trucks until 87, except for the ones built for California. Most folks think the wire going to the carb makes it a feedback carb. Then they see the wires going to the ESC and also believe it is a computer. Just so folks know, if you disconnect the sensor going to the pump solenoid, it will be in the dual capacity pump mode all the time, thus wasting gas. This needs to be hooked up and working. I bet there are a lot of owners who have removed this and wonder why they don't get good gas mileage. |
#24 |
LED King
Here is the picture in question - Everything is identical to the bottom figure except the wire & connector B. I believe this would be dual/computer while the top figure is dual/non computer.
