What is the proper way to remove/install doors on these trucks since GM saw fit to weld the hinges to the door and cab. I've done it by compressing the spring and removing the hinge pins, but it's a b!?#h! Also, how are we supposed to adjust it with the latch pin having no adjustment?
------------------ '93 1/2-ton Cheyenne 2wd 408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 375-400 HP. 4L60E w/ Trans-go kit.
'93 1/2-ton Cheyenne 2wd 408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 4L60E w/ Trans-go kit. |
| Bookmarks |
