Old 02-10-2004, 01:54 AM   #1
super72bb
Posi rear end
Hey there,
I had a long talk with a old mechanic the other day about installing a posi in my 1972 chev truck. He jumped up and down triing to tell me that "if I wanted to install a posi I would have to find a posi housing".
My argument was that they are all the same housing's and that installing a posi in my original limited slip housing was no problem. Even though I am still 90% sure I figured I would contact the experts for a third opinion. Am I right or wrong here.
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 02-10-2004, 02:32 AM   #2
SS55
Posi rear end
You are correct. The differential housing is the same. The differential carrier determines whether it is a posi or non-posi.
The carrier also determines which range of ratios you can use.
Typically referred to as a 3-series or a 4-series. A 3-series is good for about 2.70 to 3.42, then the 4-series is good for 3.73 on up. Remember to add a limited slip additive to the gear oil when you convert to a posi carrier.
Darrell
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 02-10-2004, 08:22 AM   #3
74bowtie
Thats stange I had a guy around me say the same thing, He said that I have to check to see if the ribs are on the inside of the housing if so it can't take a posi. The ribs, I have only ever seen them on the outside to give the rearend stength. I thought to myself, this guy is nuts.
69 Chevelle (Summer only ride, love to drive this)
72 Chevy Shortbox 4x2 (newest addition)
83 Chevy Shortbox 4x2 (project but its clean)
2001 S10 Ext. Cab 4x4 (daily driver)
74bowtie is offline   Reply With Quote
Old 02-10-2004, 08:59 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Don't forget to top off the headlight fluid after installing the posi unit, the increased traction will cause it to slosh around and therefore evaporate faster.
Sounds like he was confusing carrier with housing. Just keep nodding your head.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-10-2004, 04:21 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
While your under there changing the posi you may want to replace the old muffler bearing's too... Throw the posi in and show the old guy how to boil the hide's ..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-10-2004, 10:20 PM   #6
Bowtie67
Bowtie67's Avatar
Post
67 C10 I switched mine over two years ago, no issues..
Bowtie67 is offline   Reply With Quote
Old 02-10-2004, 11:12 PM   #7
Alexis
Member since 2000
Alexis's Avatar
i thought series 3 could hold a 3.73 at max and series 4 can hold 3.73 and up.
Alexis is offline   Reply With Quote
Old 02-10-2004, 11:38 PM   #8
Canada20
is it possible he meant that for a shadetree mechanic you'd need to find a complete setup, housing and all?
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 02-11-2004, 01:42 AM   #9
SS55
Alexis, you may right. I "refreshed"my memory by looking at Auburn Gear's posi carrier. Their 3 series is the 3.42 max. I thought that's what GM did as well, but that was many beers ago, so I could wrong.
Darrell
55 GMC
55 Belair 2dr HT
67 El Camino
Old 02-11-2004, 03:27 AM   #10
1969 GMC
1969 GMC's Avatar
Re: Posi rear end
posi and limited slip are one in the same.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
