Old 02-10-2004, 02:06 AM   #1
ocbaud
Garage Queen Material
will this oil pan fit?
http://www.jegs.com/cgi-bin/ncommerc...44&prmenbr=361
ocbaud is offline   Reply With Quote
Old 02-10-2004, 02:08 AM   #2
apstguy
LED King
apstguy's Avatar
I'm guessing yes. With you new engine, are you using a one-piece rear seal? Just pick the right one. We have alot of wiggle room under the engine in these trucks.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-10-2004, 02:12 AM   #3
ocbaud
no, its a 71' block, driver's side dipstick, with a 2 piece seal
Old 02-10-2004, 02:15 AM   #4
apstguy
LED King
apstguy's Avatar
Get the first one listed then.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 02-10-2004, 02:21 AM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yes, most definetely it will work. I have the one for passenger side dipstick on my truck.
Also, you will need to remark your dipstick. It won't register right. It's a 7 quart pan, so this means your engine will need 8 quarts total. So, pour 7 quarts of oil in the engine and before starting it, let it sit so all the oil gets to the pan. Then mark where the oil is at on the stick. This will be your full mark from now on. Oh, don't forget to pour the other quart in the filter.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-10-2004, 02:25 AM   #6
ocbaud
i'll be getting this also:
http://www.jegs.com//cgi-bin/ncommer...06&prmenbr=361
i figure i should get the oilpan before i drop the engine in, right
Old 02-10-2004, 10:37 AM   #7
gldevall
gldevall's Avatar
Referring back to that link, what's the difference between the passenger side and driver side dipstick pan as far as mounting? I put my dipstick on the driver's side. Are the bolt holes different?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 02-10-2004, 12:31 PM   #8
low 84
low 84's Avatar
well the dip stick goes through a hole in the block and where the stick passes the pan there is a small bulge in the pan. so the pans have bulges on different sides
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-10-2004, 01:40 PM   #9
gldevall
gldevall's Avatar
So if I ordered the one for the driver side dip stick, that also states for a pre-1980 block, it would be ok and fit?
Old 02-10-2004, 02:58 PM   #10
low 84
low 84's Avatar
i would think so, do you have a post 80 block with a driver side dipstick? if so, i could see how that would be kind of confusing.
'05 1500 Crew Cab
RIP
Old 02-10-2004, 03:10 PM   #11
gldevall
gldevall's Avatar
Not sure what year block it is. It's the goodwrench crate motor. It had the provision for either pass or driver side dipstick.
Old 02-10-2004, 07:48 PM   #12
swervin ervin
Gary,
either pan will fit on the GM Goodwrench engine, as the pan you have now has the bulges on either side of the block. I'm guessing that you put the plug in the passenger side. I opted for the passenger side dipstick on mine. The thing about these blocks is they have the bulge, but they also have a straight rail so a regular pan will work too.
Mike
1985 Chevy C-10
Old 02-10-2004, 08:58 PM   #13
gldevall
gldevall's Avatar
Mike, your great. Thanks.
