Old 02-10-2004, 09:47 AM   #1
Short-Fuse 72'
Distributor lockout
It was suggested to me that I lock out the vacuum advance on my distributor due to the size of my cam. How would I go about doing this? Is this the same as putting in a curve kit? Any help would be appreciated. Thanks.
Ya'll hear that? We's usin' codenames.
Short-Fuse 72' is offline   Reply With Quote
Old 02-10-2004, 11:43 AM   #2
bigjimzlll
bigjimzlll's Avatar
what kind of distributor? On my MSD it came with a lock out do-hickey. When I locked it out it really helped performance and drivability. I also limited my mechanical advance to 14º. This way I can set the intial timing to 20-22º(helps idle) and it wont over advance when at full advance.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-10-2004, 01:21 PM   #3
BowTieMan
BowTieMan's Avatar
So do all distrubuter's have this? What exactly is it? Does it just advance the timing? Would a recurve kit take its place? And does it help performance?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 02-10-2004, 01:51 PM   #4
Short-Fuse 72'
Mine is an Accel dist. with the supercoil cap/coil setup. I just was wondering if the lockout and curve kit were one in the same. Should I switch out my vacuum advance module with a mechanical one?
Old 02-10-2004, 02:03 PM   #5
rodnok1
rodnok1's Avatar
Recurve doesn't have anything to do with lockout. Alot of engines benefit from limiting total advance by either welding the slot closed in the distrib or by a stop of some sort. I have seen articles at hotrod /carcraft/chevy hi po about this. I you really want to just bypass the vacuum advance just unplug it and cap the ports. Vaccum advance is used primary at idle/low speed if I remember correctly.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-10-2004, 06:42 PM   #6
Short-Fuse 72'
Old 02-10-2004, 09:05 PM   #7
bigjimzlll
bigjimzlll's Avatar
the only problem with capping off the cannister is that the cannister mechanism will still allow the plate to move some..making the timing a little errattic
Anderson,CA
