Old 02-10-2004, 12:33 PM   #1
low 84
low 84's Avatar
posi
does a posi replace the carrier in the rear end or does it just attach to it.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-10-2004, 12:58 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Yes, a posi replaces the carrier. You're ring gear bolts to the posi unit just like it did to the carrier. All the other parts contained in the carrier are removed as well.
Mike
NeCrOmAnCeR is offline   Reply With Quote
Old 02-10-2004, 02:56 PM   #3
low 84
low 84's Avatar
so is there a 3 and 4 series posi? or just one posi and 3 and 4 series rings will both attach?
'05 1500 Crew Cab
RIP
Old 02-10-2004, 05:00 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
There are 3 and 4 series carriers regardless of type.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-10-2004, 07:05 PM   #5
low 84
low 84's Avatar
ok, last question. if i buy a 4 series posi and 4 series R&P that is all i need to change my 12 bolt to 4 series if it was originaly 3 series open 3.07, correct? like there aren't any other parts that are different that i must change?
'05 1500 Crew Cab
RIP
Old 02-10-2004, 07:28 PM   #6
Captkaos
Captkaos's Avatar
sure it is your last question..
Yes, when your order the gears and the differential (carrier) that will be all you need. They will(should) match your gears with the carrier.
The differential (carrier) is different due to the size of the pinion getting smaller/larger base on the gear change. A 4.10:1 ratio has a MUCH smaller pinion gear diameter than a 3.07:1 ratio, so the carrier flange that the ring gear bolts to is posistioned closer to the centerline of the pinion to make up this difference.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 02-10-2004, 07:29 PM   #7
low 84
low 84's Avatar
'05 1500 Crew Cab
RIP
