Old 02-10-2004, 07:07 PM   #1
dumpedv8
changing from 5 lug to 6 lug axles
im interested in changing my 1997 silverado 1500 2wd from a five lug to a 6 lug to run the silverado ss 20 inch wheels. ive looked at getting adapters but they a 2.2 inches thick and that is just way to thick for me to be able to lower the truck onto them. any advice you could give on how hard it is to swap or if even possible would be greatly appriciated.
dumpedv8 is offline   Reply With Quote
Old 02-12-2004, 10:13 AM   #2
bagged91
Out draggin'
bagged91's Avatar
If you can find a decent K1500 rear, I would just swap out the entire rear. That would give you the 6 on 5.5 pattern you are lookin for in the rear. As far as the front goes, you will have to swap over the spindles, rotors, ect... from a light 3/4 ton truck to get the 6 on 5.5 in the front.
Good Luck!
Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 02-13-2004, 01:00 AM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Hey bagged91, do you know if this mod would be just as straight forward for a '74 1/2 ton? Been looking at the new weels myself for my ride.
NeCrOmAnCeR is offline   Reply With Quote
Old 02-14-2004, 12:43 AM   #4
1FaastC10
1FaastC10's Avatar
necromancer, no, the mod is not that simple. unless of course you want to have a set of custom made, custom drilled rotors on the front. or you dont mind switching to a pre-70 front suspension with drum brakes.
1FaastC10 is offline   Reply With Quote
Old 02-15-2004, 03:13 AM   #5
NeCrOmAnCeR
Darn, thanks!
Old 02-16-2004, 07:06 PM   #6
Primered_69
Primered_69's Avatar
I am having my rotors redrilled for like 85 dollars for the pair
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 02-17-2004, 07:38 PM   #7
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
NeCrOmAnCeR,
GMC Paul sells 6 lug rotors that will fit on a 73-87 spindle as long as you already have the 1.25" thick rotors. if so it would just be a bolt on for the front.
not sure about the rear......
dont know if you could swap axles from a 70' with the wider rear end like the 71-72's or just have your axles and drums redrilled.
tommie is offline   Reply With Quote
