Old 02-10-2004, 08:42 PM   #1
theo70
COMING SOON...
theo70's Avatar
Installing wheel bearings
After packing the wheel bearings, should you grease up the areas that come in contact with them before you install them? And should you "fill in" the remaining area with grease before you put in the seal, or is the bearing grease enough?
Disc brakes, BTW.
theo70 is offline   Reply With Quote
Old 02-10-2004, 08:57 PM   #2
Oborny71
Oborny71's Avatar
yes , you should coat everthing with grease (between the two bearings) to keep it from rusting. all you need is a thin layer though.
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 02-10-2004, 09:09 PM   #3
Alexis
Member since 2000
Alexis's Avatar
I dunk the bearing in grease and work the bearing so i know it's coated inside and out, then I grease my finger and slide it around the area the bearing going to sit in. i think it's 20lbs of trq on the castle nut for it.
Alexis is offline   Reply With Quote
Old 02-10-2004, 10:15 PM   #4
theo70
COMING SOON...
theo70's Avatar
Thanks guys.
