Old 02-10-2004, 09:47 PM   #1
avejoe
Custer had a plan too.
avejoe's Avatar
Purpose of Heat Risers
What is the purpose of the heat risers that are located where the exhaust pipe attaches to the manifold?
Mine are missing. Is this a problem?
avejoe is offline   Reply With Quote
Old 02-10-2004, 09:56 PM   #2
casey
casey's Avatar
if I'm not mistaken, there usually on one side and it restricts the exhaust when the vehicle is cold, and the exhaust runs through the intake manifold over to the other exhaust manifold instead to help warn it up, I stand to be corrected
casey is offline   Reply With Quote
Old 02-10-2004, 09:56 PM   #3
69 air cab
Great question avejoe.........I have the same problem. I am looking for one.
69 air cab is offline   Reply With Quote
Old 02-10-2004, 09:56 PM   #4
Kenneth Brown
Not in calipornia its not. When the engine is cold the riser will close some so as to retain more heat in the motor. Its not a problem in a warm climate.
Kenneth Brown is offline   Reply With Quote
Old 02-10-2004, 09:59 PM   #5
rage'nrat638
rage'nrat638's Avatar
my header's don't have that
rage'nrat638 is offline   Reply With Quote
Old 02-10-2004, 10:01 PM   #6
jorgensensc
jorgensensc's Avatar
I took out the innards of the heat risers on my old '80,'82,'83,and'85. Your truck will eventually warm up.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-10-2004, 10:11 PM   #7
Bowtie67
Bowtie67's Avatar
Post
Adding weight, making noise, freezing up, but they were intended to help with keeping heat when it was cold out, so that more heat could be utilized with the factory aircleaner. (Dump EM)
Bowtie67 is offline   Reply With Quote
