Old 02-10-2004, 10:32 PM   #1
MJN
MJN's Avatar
Engine Stumbles
When I've got the truck in park or neutral and hold the rpm's at around 1200 the engine stumbles but if I go higher or lower it runs perfect. It's a 350 with a 750cfm quadrajet off a '71 Vette and HEI with a TH350 tranny. Any ideas what is causing this? vacuum leak, carb problems, ignition?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-10-2004, 11:57 PM   #2
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I'm no guru but 750 is a lot for a stock 350. You might be loading up in the middle rpm's but once you get to the higher rpm's its sucking up that gas better.
WRMZ71 is offline   Reply With Quote
Old 02-11-2004, 12:43 AM   #3
MJN
MJN's Avatar
It has a medium cam in it, and it runs good except for at the certain rpm +/- 100. I know the carb needs a little work and wouldn't doubt it if it is the problem. Thanks
