02-10-2004, 10:46 PM | #1 |
Windshield squirter upgrades?
The originals seem to suck, can anyone share what you you have done to upgrade, I'm looking for ideas.
Thanks |
02-10-2004, 10:54 PM | #2 |
Those little $10 motors found at JCW, Auto Zone, etc. work fine for me--so small that you can hide them and keep the original for stock appearance if that's your thing.
Stepsides look like real trucks! Smitty |
02-10-2004, 10:59 PM | #3 |
Not sure if I am on the same page as you - but I had a similar thought today. They shoot 2 narrow streams on the window, and then the wipers have to push it around. I wish mine sprayed more than just shooting a stream up there.
Can we take the tips off a newer car and use those?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-10-2004, 11:51 PM | #4 |
I PUT WINDSHEILD WIPER FLUID BOTTLES OFF EARLY 90s CHEVY PICKUPS ON ALL MY TRUCKS. THEY HOLD ALMOST A GALLON OF FLUID & THE MOTOR IS SELF CONTAINED AS PART OF THE BOTTLE. I PICK EM UP AT THE BONEYARD FOR ABOUT SIX OR EIGHT BUCKS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
02-11-2004, 12:01 AM | #5 |
Killin' Time
hmm, I haven't squirted mine since I got my truck.... don't wanna get my new water bottle dirty!
NEED CORVETTE 1972 GMC C20 350, SM465, HEI Dynomax headers and 2.5" duals |
02-11-2004, 12:06 AM | #6 |
Here is an idea, find the little square type ones that most cars have on the hood(they push into a hole in the hood), and see if it will push and seat in the cowl vent holes. The hose should hook right up to them. It's just seating them and getting them to stay that might take some thought, but it shouldn't be too hard.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-11-2004, 01:38 AM | #7 |
please post pics of aftermarket mods
Junkyardjohn,
I have heare of this mod before. Do you have a picture and maybe description of how-to? Anyone have a boneyard one to sell? thanks.
Bob |
02-11-2004, 02:07 AM | #8 |
Merciless Butcher
If you're looking for a different setup to actually get the solvent on the windshield, look at a setup on a mid-seventies Corvette. They had a small feeder tube that was hidden in the underside of the blade arm. The sprayers were on the arms themselves. It was a pretty good setup and distributed the solvent very evenly.
Your Bought And Sold....I Got Your Soul! |
02-11-2004, 05:38 AM | #9 |
English Chevy Owner
My favourite are the jets from a Jeep Cherokee, never used them on anything else but they spray a fan pattern across the whole glass. May be worth a look.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
02-11-2004, 06:22 AM | #10 |
This isn't what I've done but instead what I eventually plan on doing...have some of the parts to do it, not all yet so it hasn't began yet. I really like the spray pattern on the Acura legends (and most other acuras share the same pattern), fan pattern shot from the hood, and use a newer GM spray tank with the pump built in (already have one from an '87 C20 I parted out).
02-11-2004, 07:53 AM | #11 |
Old member
New Window Squirter
This is what I did with mine. Late model jug with pump made in it and get the wiper sprayer's also. I put them in a pot of water and heated it up so I could fit them to the wiper's on the truck. Take the wipers off and use a pair of vise grips to hold them tight over night, the next day they are there. You get spray all over the window where you need it.
02-11-2004, 08:13 AM | #12 |
its all about the +6 inches
gonebad2, the chryslers is also another place to look for the wet arm set up.
02-11-2004, 11:02 AM | #13 |
Mike
I had an 85 dodge van that had the sprayers on the arm.Plenty of them in the boneyards.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
02-11-2004, 08:01 PM | #14 |
Wow great feedback! Thanks
72 Chevy 4x4 350 55 Chevy Bel Air 350/350 53 Matchless G80s (motorcycle) 06 Trailblazer SS 400hp LS2 |
