02-11-2004, 12:14 PM | #1 |
No, U Da Man!
puzzled?
Engine is missing or sounds an acts like a burnt valve? Compression test shows 120 all cylinders, timing is good, plugs good, new plug wires, seems to smoth out after take off? I hear a popping noise when taking off too, sounds like it's coming from exhaust system. Vacuum gauge shows a constant bounce between 15-20 at idle. I removed intake, installed new gaskets cking for a good seal with a scope all ok. Vacuum gauge still bounces and still missing. Any suggestions?
(sold ole blue 1972) 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
02-11-2004, 01:24 PM | #2 |
I would be looking for a broken valve spring or a worn cam lobe.
Jim |
02-11-2004, 02:33 PM | #3 |
i'd recheck the plug wires for good contact in the cap as well as on the plugs
02-11-2004, 02:53 PM | #4 |
I remember not to long ago someone else was complaining about popping out of exhaust, turns out he had a busted Valve spring.
02-11-2004, 03:56 PM | #5 |
Carb Adj???
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-11-2004, 06:00 PM | #6 |
1FINE69
I'd go withthe bad valve spring too, since I just had this happen to me about 3 -4 months ago. Replaced the bad spring and pushrod that was bent , and everything seems good no backfire or misses.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
02-14-2004, 08:29 PM | #7 |
No, U Da Man!
Sorry for taking so long to reply, been working alot. I think I'll ck the valve springs. Thanks for all the replies. I'll let ya'll know what I find.
02-14-2004, 08:30 PM | #8 |
Designated A-hole!
Don't forget to check exhaust manifold for cracks.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
